Guest Message © 2009 DevFuse
Page 1 of 1
1989 Daytona ES Ext Locks Ext Door Handle no longer opens Rate Topic: -----
#1 Guest_DaytonaNJ_*
  • Group: Guests
Post icon  Posted 06 February 2008 - 04:50 PM
:P
Have a mint 1989 Dodge Daytona with less the 60K miles
that was in storage for a 'few' years. Pumped every yr
till 06, had to replace fuel injector. Headliner dropped one
hot day during a photo op. Go figure.
Bumper play with a crane took out my 1999 Ply Voyager
off the road. Cracked the back with it.
Anyways, dust and cobwebs aside, she purrs like a kitten.
Four months snaking the road, my passenger door handle
no longer opens the door from the outside. Opens inside
ok. Any idea if I can fix, our is my old lady handi-ed?
Anybody interested in seeing pix give a hola.
2nd car, mom bought me new in 89.
In storage since 4/07.... Pic of last insp stick to prove.
White ext, marroon interior.
Snowflakes with new skins.
Auto with 2.5l 4cyl.
#2 User is offline   soloflite
  • Prolific
  • PipPipPipPipPip
  • Group: Active Member
Posted 06 February 2008 - 05:39 PM
1st off, welcome to the forum. Here is an elite group of peeps that have years of extensive knowledge and are great people. You should find an answer for just about anything. Again welcome!
Get an alan wrench. From the doors edge towards the middle you will see an oval hole that's at an angle. use a flash light to see the alan head on the bolt. Loosen the bolt a little, adjust it and try the door again.
Other two options could be, the bar is bent and you'll need to re-bend it to catch, or the clip that holds the bar inside to the handle is broken and the bar has fallen out of the handle. You can buy these clips in the self help at parts stores for about a buck or so.
This post has been edited by soloflite: 06 February 2008 - 05:40 PM
#3 User is offline   Tonatom
  • Active
  • PipPipPip
Posted 06 February 2008 - 06:00 PM
+1 to solo, I would say the linkage has fell off
Just remove the inner door panel, takes no time at all. And take a look.
#4 User is offline   TurboPacifica
  • King
  • PipPipPipPipPip
  • Group: Supporters
Posted 06 February 2008 - 06:31 PM
I agree with above.
In my case we had to remove the outer door handle, then remove the thin bar/linkage and
WACK IT !! a few times with a hammer to straighten it out some.
Hadn't had any problems sience. :P
And yes welcome aboard. :P :lol: :unsure:
This post has been edited by TurboPacifica: 06 February 2008 - 06:33 PM
#5 User is offline   Bob Lincoln
  • "CHECK FAULT CODES"
  • PipPipPipPipPipPip
  • Group: Forum Leader
Posted 07 February 2008 - 08:50 AM
If the handle pulls normally, but doesn't seem to actuate anything, I'd bet on the Allen screw adjustment. Happened to me. Now I have it set up so a very easy pull drops the door open. No need to remove the trim panel.
#6 Guest_DaytonaNJ_*
  • Group: Guests
Post icon  Posted 07 February 2008 - 09:18 AM
Nice to be aboard.
I will give the allen key fix a try and pull off the panel if that doesn't work.
Thankyou. Will post back with results.
Chet
#7 User is offline   TurboPacifica
  • King
  • PipPipPipPipPip
  • Group: Supporters
Posted 08 February 2008 - 07:10 PM
Hey DaytonaNJ, Where in NJ are you located??
I am in Bergenfield NJ 07621
10 mins from the GWB
#8 Guest_DaytonaNJ_*
  • Group: Guests
Post icon  Posted 08 February 2008 - 09:18 PM
Linden,NJ 07036 Exit 13 on NJTP.
#9 Guest_DaytonaNJ_*
  • Group: Guests
Post icon  Posted 08 February 2008 - 09:26 PM
Fixed it!
The allen key adjustment fixed it.
BUT I still took the panel off to look if the bar was bent.
While doing the adjust, I looked at the handle height.
Turns out the 'black' handle assembly moved up somehow.
The two bolts on the rear of the handle assm were mightly
loose. Seems they used a two sided tape to center the
bracket holds the handle.
Dunno if that tape is not sticking. I loosed the bolts
and moved the entire 'black' assembly down.
Nice.
Thankyou all for your help.
-Chet
Attached File(s)
#10 Guest_DaytonaNJ_*
  • Group: Guests
Post icon  Posted 08 February 2008 - 09:46 PM
TJ, very nice work on that restoration.
How do those side louvers stay on? Two sided tape?
Nice having Ts, my 84 Z28 had em. Only non-MOPAR I had.
Maybe I'll catch you on the line at NJTP11 Shore-bound...
up at the neck. You know where :P
-Chet
#11 User is offline   Bob Lincoln
Posted 08 February 2008 - 10:14 PM
Now that I think about it, those two studs and nuts that hold the handle assembly on my car had loosened to the point where the handle almost fell off.
#12 User is offline   TurboPacifica
  • King
  • PipPipPipPipPip
  • Group: Supporters
Post icon  Posted 09 February 2008 - 01:25 PM
Hey DaytonaNJ
Post some pictures of your car so I can keep a watch out for it this summer.
Maybe you can come up and meet at some cars shows.
and with your birthday that makes me 5 years and 1 day older
good to see someone eles my age still working on Daytonas
and yes double sided tape holds on the side luvers
This post has been edited by TurboPacifica: 09 February 2008 - 05:18 PM
#13 User is offline   Bob Lincoln
Posted 09 February 2008 - 10:00 PM
Quote
:blink: ???
I'll be 47 in April. Bob O' has a few years on me. We middle-aged people are the majority of those working on Daytonas, I think. Not nearly as many in their 20s, like we were when we bought them new. I've had Daytonas for 22 years.
#14 User is offline   MNmopar
  • Active
  • PipPipPip
  • Location:Nisswa Minnesota, by way of Sturgeon Bay, Wisconsin
Posted 09 February 2008 - 11:08 PM
I'm 32 and I've had 3... none new though.
But although I've worked on them for years, I wouldn't say that I was restoring them... just trying to keep them on the road.
My "new" car is going to get babied though.
#15 User is offline   TurboPacifica
  • King
  • PipPipPipPipPip
  • Group: Supporters
Posted 10 February 2008 - 09:04 PM
I bought my first Daytona New in Aug of 87 there was evan a new 88 next to it at the dealer.
I got a better price on a left over evan though it only had 8 miles on it and the plastic still on the seats.
so then I had that car from 87 to 93 then didn't have another Daytona till 2004 and sience then now I am
on my 5th Daytona and I also still have my 4th so thats a total of 15 years working on Daytonas
This post has been edited by TurboPacifica: 10 February 2008 - 09:06 PM
Page 1 of 1
