Guest Message © 2009 DevFuse
Page 1 of 1
axles on 95 caravan...differences? Rate Topic: -----
#1 Guest_NeilH_*
  • Group: Guests
Posted 28 April 2008 - 10:27 PM
This is a weird one, its just that it got late and dark out in the parking lot where I have been doing a transmission replacement so Im tired and dont have the energy to investigate.....however....
1995 dodge caravan, 3.0 3 speed auto
My Brother who is a mechanic by trade (although a state away) had a good tranny sitting in his shop and he gave it to me. He also gave me the drive axles, in case they were in better shape than the ones I had. He confirmed with me the year, and that it was in fact a three speed. (This trans is from this generation, although Im not sure of the year, it seemed identical so far)
He also said that in case the tranny was a little different, i may have to use the axles that he gave me for it to work out.
In any case, my plan was to pick the better of the axles to use. The long side units were exactly the same length so I just picked the one with the better boots. When it came tiem for the short side, I could only locate one of them and it looked fine so I out it in. It was kind of hard to wrestle it into place (the long one went in much easier). I had the two big bolts out of the shock and the tie rod popped out. (lower knuckle was undisturbed)
Anyway, paranoid that I am, Im a little worried about how hard it was to get the short axle in, and it seems that the wheel on that side is out of alignment somewhat.
I really dont know if I put the short axle in from my brother or the one that had been in the van. (or that it would even matter) I am really scratching my head as to where my other axle went. They were on my porch....and the other set was in my van.
I know there were several manufacturers for the axles/cv joints, but all else being equal I think it would not matter as long as you used the entire unit...
Should I assume that since the tranny was indentical and the long axles were exactly the same length that the short axles would probably have been the same as well?
#2 User is offline   poorboy_616
  • Post prostitute
  • PipPipPipPip
  • Group: Active Member
Posted 29 April 2008 - 01:17 AM
Considering I just did the driver side axle on our 94 T&C a few hours ago, I can give you the answer you are looking for....
I also had trouble with the short axle on mine, even though mine has the 4 spd.....(same axles as the 3spd BTW)
Due to the lack of length, which limits the movement for installation, you will have had trouble with it. I know I did, but I got my hand in there and guided it into place with out issue.....
It sounds like you did exactly what I did, pop the tie rod and swing the knuckle over.
Now for the other side...(that will be tommorow or wednesday....)
#3 User is offline   lcb2005
  • Normal
  • PipPip
Posted 29 April 2008 - 10:33 AM
Those transmissions will interchange through all the years, Ask me how I know.
Also if you took the two bolts from the strut you will need an alignment if you didn't mark the bottom one.
This post has been edited by lcb2005: 29 April 2008 - 10:39 AM
#4 User is offline   fjb37
  • Unusually Active
  • PipPipPipPip
Posted 29 April 2008 - 10:48 AM
Adjust the bottom bolt until the wheel looks perpendicular to the ground. That will be good enough until you can get to the alignment shop. The setting is from -0.2 deg. to +0.8 deg. with +0.3 deg. prefered. Just my $0.02.
FredB
#5 User is offline   poorboy_616
  • Post prostitute
  • PipPipPipPip
Posted 29 April 2008 - 10:56 AM
I used silver spray paint to mark mine.....
I think I hit the mark spot on, but I will get an alignament once it's done, just to be sure....
#6 Guest_NeilH_*
  • Group: Guests
Posted 29 April 2008 - 02:53 PM
Thanks guys!
The missing short axle was under the van towards the back. What I get for working in the dark.
Boggles the mind to think that all of us are out there doing this! LOL
before this, the most I had done on a tranny on one of these vans was to drop the one in my 2000 caravan just enough to replace a cracked flex plate....I had done the axles on my old '93 once too....
Oh god why do we bother?
Its a love-hate thing for sure. I have some more things to hook up but wont get to it til later.
This post has been edited by NeilH: 29 April 2008 - 02:54 PM
Page 1 of 1
