73_duster, on Jun 28 2008, 03:54 AM, said:
I just rebuilt a 360ci engine and its ready to go, but... With it being externally balanced, would it be safe to break in the engine outside of the car without being connected to the torque converter? Has anyone dealt with this or know some good tips? Any advice would be helpful.
And also is the best way to break it in, to just rev it in short spurts and keep it above 3000rpm? Or is there an even better method?
The main differnce between the roller cam engines and the flat tappet cams is, a roller engine can be started and at idle immediately, the flat tappet engine needs to be between 1500 and 2000rpm (NOT 3000rpm, too hight) to break the cam in for 20 minutes, then the oil change, then, as mentioned, cool down, then drive for about 20-30 minutes on the street, medium speeds up to 3500rpm shifts, double check for leaks and things tied down, another cool down time, then go out and drive her normal, no burnouts, high rpm shifts, up and down, 20mph increases and decreases, change the oil at 500miles and then you can do whatever you want. Race and strip engines are quite a bit different because they aren't expected to last over 100,000 miles of trouble-free driving.
