Guest Message © 2009 DevFuse
Check out these pages...
2.2/2.5 TBI mods - Neon upgrades- our engines pages, and small V8 performance upgrades. And, post your performance topics here.
Page 1 of 1
Engine help!?! I might be in MAJOR Trouble! Rate Topic: -----
#1 Guest_73_duster_*
  • Group: Guests
Posted 04 July 2008 - 07:52 PM
Being the kind of person who does before they think... I sat my my freshly self ported intake manifold on the engine, forgetting to do a final clean. I pulled it back off to lay on the gasket and saw little pile of aluminum shavings on the top of the block next to the push rods. I cleaned most of it up but will anything happen with the shavings being the soft aluminum? They are very very small fragments. Please, anything will help.
I am also slightly concerned about my carb, I turned it half-way upside down to get it out of the bag with one hand and i heard something ratteling on the sides. Is something just opening and closing, or did something fall off?
This post has been edited by 73_duster: 04 July 2008 - 08:00 PM
#2 User is offline   Bob ONeill
  • 295,000+ miles and counting...
  • PipPipPipPipPipPip
  • Group: Supermen
Posted 05 July 2008 - 05:33 PM
Let me share with you my tail of woe and then 'suggest' a plan of attack.
I had my dad glass blast a manifold. The outside was clean and the inside was blown out but.....
I installed it on a 440 and tried to crank it up. Needless to say we had to pull the engine apart to re-ring it. The glass got in everywhere and tore up the insides of the enigne.
Now to your trouble.....
It seems that if you haven't cranked it up and if you're sure that none got in the crank case here's what I suggest.
Use some liquid like thin oil mixed with mineral spirits or something like that and clean everything. I say this because you can vacuum it up and with some luck get all of it out.
But if you really want to be on the safe side drop the pan, pull the pistons and clean EVERYTHING with both liquid solvant and air to insure that there are no tiny bits anywhere that can muck up the works.
#3 User is offline   chuzz
  • Unusually Active
  • PipPipPipPip
  • Group: Active Member
Posted 06 July 2008 - 09:11 AM
Since you haven't fired it up, you can do as Bob suggested with the oil and then use a shop vac. Or just use the shop vac and then take a very bright light to see if any particles remain. Keep in mind that it doesn't take a very large particle to lock up an oil pump.
#4 User is offline   CandyBlues
  • Moderately New
  • Pip
Posted 30 July 2008 - 11:07 AM
I think you should take it to a professional who actually knows what theyre doing because i don't think you should take the chance of messing it up even more...Id like to know how it turns out so let us know
#5 User is offline   wittsend
  • Normal
  • PipPip
Posted 01 August 2008 - 12:04 AM
The rattling sound is the floats. Good, they are not hung up.
Get yourself a bright flashlight and at a dark time and look the engine over real well.
It doesn't sound like anything went into the engine, " - and saw little pile of aluminum shavings on the top of the block next to the push rods." Again, just check it over real well. Did any bits go down the oil drain back holes?
I would use a vacuum - then paint thinner (or similar solvent - brake parts cleaner) if particles are found clinging with oil. DON"T VACUUM THE SOLVENTS! Plug the drain back holes with paper towels. Then wipe out any particles. Just make sure nothing goes down the oil drain holes.
Tom
This post has been edited by wittsend: 01 August 2008 - 12:04 AM
Page 1 of 1
