Useful Links
AllPar | EEK! Mailing List (Lots of EEK! Information and Repairs) | Chrysler K Car Club | All cars EEK Photo Gallery
No Windshield Wipers + Rain = Bad Rate Topic: -----
#1 Guest_mikeh33_*
Posted 19 August 2008 - 05:57 PM
This is probably a silly question, but hopefully someone here can help me.
After months of no rain to speak of, we've finally been getting some nice storms in my neck of the woods. Naturally, this is when the windshield wipers on my '89 LeBaron decide to give out - sticking straight up, in mid-wipe, in the middle of a rainstorm.
I pulled to the side of the road, and was able to lower the wipers with no problem. But nothing happens at all when I turn the wipers on. I hear a clicking noise, and what sounds like the wiper motor running, but the wipers don't move at all at any setting. I tried replacing the fuse (a long shot, since the wiper motor seems to be running) - no dice.
Does anyone have any suggestions as to what I should look at next? I have one of those service manuals you get at the auto parts store, but it's not helping me a whole lot. Thanks in advance.
#2 User is offline   95 acclaimV6
  • Normal
  • PipPip
  • Group: Active Member
Posted 19 August 2008 - 06:24 PM
Sounds like the motor is good but the linkage that connects to the motor might have broke or came off. Take off the cover that covers the motor and thats most likely what happened.
#3 User is offline   patricklynch
  • Happy R body St. Regis driver, blissed out Plymouth VIP owner
  • PipPipPipPipPip
Posted 19 August 2008 - 06:35 PM
I also have an '89 LeBaron. My wipers did the same thing because the pivot bushings gave out. It's not hard to replace them, I pasted in below what I did to fix the problem from an earlier thread. Hope it helps.
The pivot bushings can be found on the Help! rack of any parts store. All the post 1979 Mopars seem to use the same bushings.
1) Remove both windshield wipers from their pivots. Use a flat blade screwdriver to release the little slider that locks the wipers down before removing.
2) Remove the plastic cowl cover. Do not remove the hood to cowl weatherstrip. It's not necessary. Oops. rolleyes.gif
3) Remove the plastic wiper motor cover and the plastic grate pieces just below the windshield wiper pivots.
4) Remove the 10mm windshield wiper pivot mounting bolts from both the driver and passenger side wipers.
5) Remove the three 13mm wiper motor nuts. If you haven't done so already unplug the wiper motor harness.
6) Lift the wiper motor free from it mounting bolts. Once the motor is free, you can slide out the whole wiper arm assembly along with the linkage.
7) Since I had already lost the passenger side bushing, I used a combination of a large washer, a deep socket and a pair of channel lock pliers to press the bushing into the wiper linkage. I put a tiny dab of grease inside the bushing and used a washer to protect the upper surface of the bushing to press the wiper pivot in place at the bottom of the bushing.
8) Cut the other bushings off with a sharp knife, and repeat step 7.
9) Feed the wiper linkage through the firewall hole and put the wiper motor back onto the mounting bolts. You can use the holes where the plastic grates were removed to get hold of the pivots and swing them back in place.
10) Use at least one bolt to tack the pivot back in place. Do the same thing on the other side. Then put in the rest of the bolts and put the retaining nuts back on the wiper motor and plug the harness back in.
11) While the cowl cover is off, activate your wipers and watch for operation. Everything should be smooth and quiet with no binding.
12) If you havent' done it already, now is a good time to remove leaves or other debris out of the cowl.
13) Put the wiper motor cover back on and replace the plastic grates to keep debris out.
14) Put plastic cover back on. If the plastic retainers are trashed, replacements are easily available from the Help! section of any auto parts store.
15) Replace windshield wipers on pivots. You should be good to go!
This post has been edited by patricklynch: 19 August 2008 - 06:38 PM
