96 Stratus Hvac Problem Rate Topic: -----
#1 Guest_jp3ssp_*
Posted 07 September 2008 - 03:45 PM
The HVAC doors on my Stratus have started acting up, they will not stay in position. As you drive they go from a/c vent to heat to defrost and then wherever they want to go. They are electrical and not sure if it is the switch or the motor. Anybody else have this problem or know the solution let me I could use some help.
Thanks John
#2 User is offline   the cp
  • Active
  • PipPipPip
  • Group: Active Member
Posted 07 September 2008 - 11:26 PM
I used to have the same problem on my 95 Stratus. No matter what setting I put it on, it would mostly stay on "defrost" but would occasionally kick down to the dash for a while.
It mysteriously started working again, so I won't be of much help. I can only wish you luck in figuring it out.
#3 User is offline   ImperialCrown
  • Prolific
  • PipPipPipPipPip
Posted 08 September 2008 - 02:52 PM
The BCM or possibly HVAC modules may hold stored fault codes to give you some direction to go in.
#4 Guest_jp3ssp_*
Posted 08 September 2008 - 07:42 PM
This afternoon it was working fine so i hope it was just a fluke but I might have a reader hooked up and see if any faults are on it. I never thought about fault codes so thanks
John
#5 User is offline   Bartdude
  • New
  • Group: Members
Posted 05 September 2009 - 06:26 PM
Probably bad Climatte control module, I just put a used one in my daughter's 98 cirrus today, had that problem plus the fan control quit working, got lucky, local junk yard had a 99 control module for $45, though I have seen them up to $149 on internet. Stratus/cirrus same item, and 97 to 2000 supposed to be same unit.
try this link if you want to test your control module: http://autorepair.ab...faqs/bl163h.htm
Not real hard, just tedious to replace, 2 electrical connectors, but the clips on the cables for temp control and outside air damper can be tricky to get in the right place....
To replace, you will pop off the trim piece around control and radio, a few screws to remove top dash, that's easy. Then remove console piece under that, unless you have cd changer, then that comes out too. That part is easier than it sounds, unscrew and unplug. Then remove screws holding control unit and drop down. remove electrical connectors, then carefully remove clips on the two cables, and don't let those clips fly away. Mark which cable goes on the left and right. Reverse with replacement unit....
