I am installing an MS ignition and coil for my car due to fouling plugs and cold winters. I have chosen the Mallory HyFire ignition box (digital) with rev limiter, the specs show a very low current draw but a higher output then leading companies, and is cheaper. If anyone has anything bad to say about this box, then feel free to say. I now have to select an ignition coil and I'm a little confused about how to choose one right for my vehicle.
The car is a 73 duster with a 360ci., street/strip engine, mild cam, 9.3:1 CR. blah blah blah. And I'd like to choose a coil that works well until about 6000rpm. The problem is that companies i've looked at don't give the power range of there coils. And on top of that, articles about choosing the right coil that I have read don't make sense to me at all.
So basically, in a coil, what do you really need to look at to get good spark and a power range you need? If anyone has the answers, I'm curious about a few things.
1. Whats the difference in faster turns ratio compared to slower turns ratio?
2. How does maximum voltage affect the engine performance? does it affect the power band? or altogether, is more better?
3. How does the peak current affect the performance?
4. How does the spark duration affect performance?
5. What is inductance? And how does it affect performance?
6. How can I easily compare different coils when the resistances are different?
7. And lastly, what coil specs would be in a ballpark of what I need for my engine?
Thanks for all who answer, and I think this post could also benefit others, because I've heard that there is a lot of misunderstanding when it comes to coils.
P.S. Dana44, thanks for the answer about my carb. question a while back. When I checked back on the post, I figured it wasn't worth reviving it, so I never responded.
This post has been edited by 73_duster: 13 December 2008 - 06:26 PM
Sign In
Register
Help
MultiQuote
