I have heard alot of horror stories about the chrysler transmission troubles. I am looking to but a used dodge mini van and would like some good advice from you on these, the trasmission with the 3.0 l or the transmission withe 3.3, is one better than the other?
Mini Van Trnsmissions-3.0 And 3.3, Are They is one better built than the other
#1 Guest_jamy_*
Posted 21 December 2008 - 04:00 PM
#2
Posted 21 December 2008 - 04:31 PM
The thing about horror stories is that they grow each time they are told, until everyone believes that they are 100% true without question.
The 4-speed automatic (the A604/4xTE model) in my 1995 Grand Voyager is running fine at 190K miles, although it has developed a seal leak recently. The 4-speed auto in my 1998 Grand Caravan is fine at just under 120K miles, and the one in my 1998 Stratus is fine at 150K miles, but I do have a leak at the trans fluid cooler that I need to tend to.
Basic fluid changes and not abusing them when driving has been all I've done.
#3
Posted 22 December 2008 - 08:07 AM
We've had some of all and will only buy 3.3/3.8 four speeds now.
#4
Posted 23 December 2008 - 07:49 PM
Transmissions for the 3.3 and 3.8 can be finicky. I have encountered several minivans in the junkyard that were in excellent shape save for the transmission. Used, working transmissions are nearly impossible to find, but bad trannys can also be rebuilt.
These are observations I have made over several years of working on vehicles, but my tranny experience is limited to removing and installing them. I still believe there are little creatures running around inside and pulling levers to make the gears shift. However, if I had to pick, I'd choose the 3.0 with the 3 speed. It has been my impression that the 3-speed has fewer issues, and that they either work or they don't. The 4-speeds seem to have some common glitches such as "bump-shift" or going in and out of "limp mode". I think they are electronically controlled as well.
Anyway, that's what I have seen. Stop by a reputable tranny shop- they'll give you actual knowledge, instead of my ramblings!
#5
Posted 23 December 2008 - 11:15 PM
Still shifts fine, and I have kept the fluid exchanged yearly.
#6
Posted 23 December 2008 - 11:37 PM
#7
Posted 05 November 2009 - 12:53 PM
I have a 1991 5th ave that had a "rebuilt" trans at 45000 (I see no evidence that anyone touched that transmission)still going fine but only has 74000 miles (little old lady car) I've had 3 other 4 speeds with 1 over 185000 (new pump seals) 1 over 120000 and 1 at 80000 (later model)
A couple known problems. Wrong fluid, front pump seals and the valve pack acting up (some trans shops rebuilt the trans due to this) (go to the Dodge dealer 1st).
Good luck
