Guest Message © 2009 DevFuse
Sponsored by PolyBushings.com!
Questions? Visit the PolyBushings.com forum on Allpar!
Read these first!
Common Repairs | Old Post Archives | FWD Trans Fixes | Stalling | Dealer Issues | Transmissions | Cooling | Head Gaskets | Computer Fault Codes!
If you can't find what you're looking for from the above links post your question or problem here.
Page 1 of 1
Intrepid And Neon - Both Below 0f, Not Start, Still Dead. About 1 month apart identical problems Rate Topic: -----
#1 Guest_Bruce Westfall_*
  • Group: Guests
Posted 02 February 2009 - 01:43 PM
2 days ago, the temp was about 0F. We tried to start our 2002 Neon and it would occassionally fire, but never start. I ran the battery down quickly, but jumped it and kept trying at variuos times as it warmed up to no avail.
Near the end of December, my son's 1995 Intrepid had done the EXACT SAME THING! I just replaced the crank sensor ( Goodbye 50 bucks!) and it did not help. I have no diagnostic tools, just part swapping ones, so please don't ask me what the shape of the signal was on an oscilliscope! ;)
What would these 2 cars do the same thing at around Zero dgrees?
The valves open and close, and after a bit of cranking the smell of gas shows that fuels must be present.
Any ideas?
#2 Guest_Bruce Westfall_*
  • Group: Guests
Posted 02 February 2009 - 01:55 PM
Please help soon.
I had to borrow a CHEVY until one of these is fixed!!
I do have a digital volt/amp/ohm meter if that would help anything.
#3 User is offline   bill4253
  • Active
  • PipPipPip
  • Group: Active Member
Posted 02 February 2009 - 02:09 PM
Change the spark plugs. Plugs with worn electrodes increase the power needed to fire them at very low temps.
I had the same situation several years ago when we had a two week period where -10F was considered warm. Thought it was the battery, but a new one did no better. Changed the plugs and everything was fine.
#4 User is offline   valiant67
  • Rich, Corinthian Leather
  • Icon
  • Group: Supporters III
Posted 02 February 2009 - 02:19 PM
Even with no diagnostic tools you can pull the codes, at least on the Intrepid, maybe the Neon
http://www.allpar.com/fix/codes.html
I'd also VERY CAREFULLY try a shot of starter fluid down the throttle body. if it starts and stall it is fuel related. It still could be even if you smell gas.
Then next I'd pull a plug and check for spark.
#5 User is offline   chuzz
  • Unusually Active
  • PipPipPipPip
Posted 07 October 2009 - 12:47 PM
Believe it or not, your plug wires can cause this. If they're old and have a lot of miles on them, you need to replace them. The resistance is probably no good anymore. I've seen this happen on numerous cars over the years. Old plug wires and cold weather don't go together. I have no idea how I hit this topic from back in February. I'm going to guess it's been solved by now. LOL
This post has been edited by chuzz: 07 October 2009 - 12:49 PM
#6 User is offline   Bill R
  • Unusually Active
  • PipPipPipPip
Posted 07 October 2009 - 11:46 PM
A friend of mine had a 96 Ford truck with 302 engine -same problem - it was the spark plugs!
#7 User is offline   chuzz
  • Unusually Active
  • PipPipPipPip
Posted 10 October 2009 - 08:18 AM
Hey Bill R, did you notice that his post was from February of this year? I didn't until after I had replied. I doubt that he will be back for suggestions. LMAO
Page 1 of 1
