A guy dropped off a car a few weeks ago in pieces. It was an 96 Dodge Avenger that had lost it timing belt and the guy tried to fix it himself.
Anyways he had me swap an 05' Dodge Neon block with a rebuilt head from the same 96' Dodge Avenger back into the Avenger. The swap went entirely smooth, however I get no spark. I can the full pump kick on, and I have even bypassed relays for the Automatic shut down(ASD) & fuel pump relays to make certain they were not causing the vehicle not to start. I have no voltage to the ignition coil. I ran the harness from the Crank position sensor(CPS) by the oil filter on old 96'engine block to the front of the motor under the starter on the 05' engine block. (note: the guy had hacked all three wires to the CPS and wire nutted them before it got to me, so I wired them to the 05' sensor in the same orientation but I am not 100% certain that this is proper. The guy does not want to buy service manual for $100, so if anyone has the engine bay wiring schematics and could be real nice to share that would be great)
I have no voltage to the coil (and of course, no spark), but I can make the fuel pump work and bypass the ASD relay as well. Car cranks over great!
I have a full scanner with diagnostics, but there are no codes.
Also, the wires to the relays had cracked and exposed insulation, and probably had short across each other. I seperated the broken wires and taped them off.
The guy got another PCM from another car and we dropped that in to see if that would work, but still no spark.
I'm thinking it's an electrical issue with a bad part or more broken wires...
Any ideas?
Sign In
Register
Help
MultiQuote
