Ok...I have a 93 spirit 3.0 that start one day and not another. I bench tested the starter and it works. I replaced the starter relay witch buzzes when i turn the key. Neutral safety switch works. I replaced the ignition switch. Battery is good and it still doesn't want to start. There is power to the starter but it doesn't spin or make noise. When I replaced the ignition switch it started right up. I turned it on and off 5 or 6 times and it worked. I drive to work and at the end of the day it doesn't start so I have to take the dang bus home. I'm so frustrated. I don't know what else to do.
| Guest Message © 2009 DevFuse | |
Electrical Problem Starts when it feels like it
#1 Guest_Col_*
Posted 14 March 2009 - 10:20 AM
#2
Posted 14 March 2009 - 10:30 AM
Both of these would likely make themselves known in other subtle ways when the car is running, such as stumbling at idle. Just two more things to check anyways.
#3
Next time it doesn't start, whack the starter. Or even better if you have someone to help, hold the key to start and whack the starter.
I had 2 94 LeBarons with 3.0s. Both had starters that failed soon after 100k. But I was never stranded because hitting the starter got them home, I believe it's the contacts inside that corroded. I just used a junkyard starter for $12 of the other design. One was Bosch, one was Denso. One had this problem, the other did not.
#4
Posted 14 March 2009 - 11:32 AM
He said it won't turn over.
You say you have power at the starter, if that's the case then it's got to be either a bad ground or the starter itself. Likely the starter itself.
#5
Posted 14 March 2009 - 03:08 PM
#6
Posted 15 March 2009 - 03:01 AM
#7 Guest_Col_*
Posted 19 March 2009 - 03:11 AM
Sign In
Register
Help
MultiQuote
