My 93 spirit has been having this problem for awhile now. I first noticed it when I let my foot off the gas I instantly start to stop and my front driver side hub cap melted. I took the wheel off and my brakes where worn down to nothing on the driver side so i replaced the caliper, pads, and rotor. I get the same thing, a hot wheel and my car doesn't roll or coast. This goes on until driver side pad brakes and destroys caliper #2 rotor #2. I replace caliper, rotor, pads, and wheel bearing hub and this rotor is still getting hot. My cv boot is completely shredded and all the grease leaked out. Could the cv joint generate that much heat to make my rotor hot. Could my brake lines be messed up. I'm saving for a new car but this piece needs to last a little longer. THANKS A BUNCH!!
| Guest Message © 2009 DevFuse | |
Red Hot Glowing Rotor
#1 Guest_Col_*
Posted 14 May 2009 - 09:19 PM
#2
Posted 14 May 2009 - 09:25 PM
The problem may be the bearing. If it's bad the rotor will not be at 90 degrees to the caliber and if it's cocked a little it will rub without pedal pressure.
The other possibility would be a bad hose on that side. If the inner lining of the hose is bad it could accept pressure but not let it flow back to the master cylinder on the side with the bad hose.
#3
Posted 14 May 2009 - 09:29 PM
I would have stopped driving it altogether before it got to that stage. The dragging and the smell would have been positive warning not to go further.
#4
Posted 14 May 2009 - 11:37 PM
Col, on May 14 2009, 07:19 PM, said:
You have an inner and outer brake pad, as you know. Are they worn down evenly? If so, the hub (thus both rotors that you replaced) is probably still in alignment. If it were at an angle, you'd have seen strange wear on what's left of the pads and rotors.
#5
Posted 15 May 2009 - 01:25 AM
#6 Guest_Col_*
Posted 15 May 2009 - 09:41 AM
#7 Guest_Col_*
Posted 16 May 2009 - 12:31 AM
#8
Posted 16 May 2009 - 07:12 AM
#9
Posted 16 May 2009 - 04:30 PM
Sign In
Register
Help
MultiQuote
