My lights flickers at night all the time is my pt. the only one. HELP!!!
| Guest Message © 2009 DevFuse | |
2001 PT - light flickering / waving all lights flickers
#1 Guest_jeff mcquaid_*
Posted 10 October 2004 - 09:36 PM
#2
Posted 11 October 2004 - 10:50 AM
This post has been edited by Kelownacruiser: 11 October 2004 - 10:50 AM
#3 Guest_jeff mcquaid_*
Posted 11 October 2004 - 02:10 PM
#4
Posted 12 October 2004 - 01:07 PM
#5
Posted 12 October 2004 - 05:18 PM
#6
Posted 12 October 2004 - 06:37 PM
#7
Posted 13 October 2004 - 09:33 AM
#8
Posted 19 October 2004 - 01:06 PM
I have a 2002 PT .... and I have a friend that just bought a 2004 PT .... also having the same problem .... It seems to be like an AC ripple is on the dc line ..... I have close to 60K on my car now and I complained about it to the dealer ..... before my warrenty come up .... they replaced the Alternator and I still have the same problem . It seems to be worse at times . I'm hoping (lol :lol: ) Chrysler does something about it because it is distracting on the highway at night and your lites do funny things on you !!!!!!! :unsure:
#9
Posted 19 October 2004 - 05:52 PM
Some keys to troubleshooting are, if it doesn't do it when the car is off and not moving, it is not the battery or alternator. Turning the wheel and it does it means it is in the steering stock, if it doesn't it isn't. If over bumps could be a loose wire somewhere anywhere from the switch to the headlights.
Do us all a favor and, if you can do some actual troubleshooting to determine what the problem is, since it appears to be very isolated, one 2001 and one 2002 model, not all of them (mine doesn't and I have driven about 1500miles with the headlights on in three days last month), you have a specific problem not a recall.
I want to help, but you don't live next to me so I can't get over to your house tonight, meaning I have to ask you to look at different things to fix this problem, or, find a reputible electrical shop that can help locate the problem. It may be something as simple as a loose ground or plug, a wire that has broken somewhere and is not visible or even resting near a metal edge of the body and grounds out when going over a bump (I don't know, I haven't seen your car to help fix it).
Think of this as the movie Apollo 13. You have a problem and we can only fix it with what we have in front of us, namely a computer and words, and you in turn have to do the checks for us.
#10
Posted 24 October 2004 - 09:34 AM
#11
Posted 24 October 2004 - 09:48 AM
#12
Posted 25 October 2004 - 08:45 AM
#13
Posted 25 October 2004 - 03:54 PM
#14
Posted 26 October 2004 - 03:10 PM
After re-reading your post, I assuming you're talking about your headlights? what about the dash lights? And what year, model? :huh:
#15
Posted 27 October 2004 - 11:27 PM
#16
Posted 22 November 2004 - 03:06 PM
#17
Posted 22 November 2004 - 05:27 PM
Basically the steering wheel needs to be pulled, the wiring running to the turn switch/light stock needs to be disconnected and pulled out completely to look at the wiring, replaced or repaired to prevent the short, or, the ground strap (not sure where it is or how it is wired up) is loose or breaking its connection when the wheel is being turned. Has nothing to do with the alternator. Do one quick check to make sure there isn't a wiring harness that is touching anywhere along the steering column down to the rack and pinion portion before removing the steering wheel to alleviate that as a possibility first.
Good luck and keep us informed of the progress.
#18
Posted 23 November 2004 - 08:50 AM
Thanks deedee
#19
Posted 23 November 2004 - 01:47 PM
Note, and edit: If the lights are turned on, nothing is touched and the lights then flicker, I don't know of anything electrical or electronic that is within the wiring or along the power source for the headlights that may be surging to cause this problem (but this doesn't fit the profile of when they flicker from your description). Please correct if I am wrong.
This post has been edited by dana44: 23 November 2004 - 01:50 PM
#20
Posted 23 November 2004 - 03:09 PM
Thanks deedee
Sign In
Register
Help
MultiQuote
