Guest Message © 2009 DevFuse
  • (19 Pages)
  • 1
  • 2
  • 3
  • Last »
Chrysler Patents and Trademarks Rate Topic: ***** 1 Votes
#1 Guest_hemidakota_*
  • Group: Guests
Posted 14 June 2005 - 11:00 AM
What is coming soon....some interesting stuff to post here.
Minivan - patent 6,905,155
Multiple height load floor system -In a motor vehicle having a cargo area over an in-floor recess for storing a spare wheel and tire, a multiple height load floor system for covering the in-floor recess provides the option of selecting the depth of the recess. The floor system is adapted to allot a lesser volume to the in-floor recess for use with an undersized spare, or a greater volume when a full-size spare is provided. In a motor vehicle with folding seats, the folding seats are selectively raised or lowered to align with the upper surface of the load floor system in its selected position, in order to present a substantially flat surface for carrying cargo. The selective raising or lowering of the seats and the floor system can be achieved through manually actuated or electrically powered mechanisms
Trucks - Patent 6,905,162
Truck cargo box enclosure - A tent enclosure for a pickup truck cargo box includes a pair of support tracks mounted to the side rails of the cargo box, a number of flexible support rods connected to the support tracks, and a fabric siding spanning the support rods and connected to the support tracks. The flexible support rods can be made up of multiple sections linked together, and, being longer than the width of the cargo box, describe an arch when connected to the support tracks. The forwardmost support rod can be secured to the truck cab. The fabric siding includes a U-channel edge for engaging the support track on each side of the cargo box, and is stretched over the support rods. The tent enclosure includes a door assembly for the end of the cargo box, which may be formed of fabric and integral with the fabric siding.
Engines - Patent 6,895,919
Even-firing, fully balanced, V-twin engine - A V-twin engine includes a two cylinder reciprocating apparatus, having a pair of connecting rods joined to a crankshaft through a pair of connecting rod journals that are centered at a common throw radius from the crankshaft axis, and angularly displaced from one another along the throw radius by an angular displacement equal to an included angle defined by axes of the cylinders, so that the pistons will move in unison and each reach top dead center (TDC) and bottom dead center (BDC) in their respective cylinders at substantially the same time. The cylinders fire alternately on sequential rotations the crankshaft. Counterweights on two balance shafts rotate in a 1:1 rotation ratio in a direction opposite to the crankshaft, with forces from the balance shaft counterweights and a crankshaft counterweight alternately aligning and opposing for counterbalancing vertical forces and unbalance loads in the engine.
Jeep - Patent 6,890,014
Conversion vehicle - An apparatus is provided for enabling the enlargement of the cabin for a vehicle having an enclosed cabin and a cargo bed extending rearwardly from the cabin. The apparatus includes a rear wall removably coupled to the cabin. A guide element is positioned along a floor of the cargo bed and a base portion of the rear wall is slideably coupled to the guide element, which enables the rear wall to be translated rearwardly from the cabin to vary a volume thereof.
This post has been edited by hemidakota: 14 June 2005 - 11:14 AM
#2 Guest_hemidakota_*
  • Group: Guests
Posted 14 June 2005 - 11:15 AM
Engines - Patent 6,895,925
Internal combustion engine having three valves per cylinder - A valve train is disclosed for an internal combustion engine having a block, a camshaft in the block, and at least two push rods actuated by the camshaft. The valve train comprises first and second rockers, and three valves. The first rocker is actuated by one of the push rods, and the second rocker is actuated by another of the push rods. A first valve is associated with a cylinder of the engine and actuated by the first rocker. A second valve is associated with the cylinder and actuated by the first rocker, and a third valve is associated with the cylinder and actuated by the second rocker.
#3 User is offline   skidsmadawg96
  • Allpar's Signature Policeman!
  • PipPipPipPip
  • Group: Forum Leader
Posted 14 June 2005 - 01:13 PM
dang...
#4 User is offline   marlon_jbt
  • Active
  • PipPipPip
  • Group: Active Member
Posted 14 June 2005 - 01:31 PM
V4 Engine? Am I reading that right?
#5 User is offline   thehemi
  • Normal
  • PipPip
Posted 14 June 2005 - 02:26 PM
3 Valve Hemi? :D
#6 User is offline   faterotong
  • Active
  • PipPipPip
Posted 14 June 2005 - 02:43 PM
I don't understand the minivan floor thing...can anybody help me out here?
#7 User is offline   hemicharger
  • Moderately New
  • Pip
Posted 14 June 2005 - 02:55 PM
Not a V4 but a 3 valve pushrod engine. Perhaps the updated Minivan 3.8 will get it.
#8 User is offline   faterotong
  • Active
  • PipPipPip
Posted 14 June 2005 - 03:15 PM
I wonder how much boost in power that'll give it? Hopefully at least 250 just to keep up with the imports...and that 6-speed tranny'll help a lot I hope.
#9 User is offline   DaveAdmin
  • Administrator
  • PipPipPipPipPipPip
  • Group: Supermen
Wouldn't be the first time, I think Honda used to have a three valve engine. Guess it's a way to avoid VVT in the new 3.8/4.0.
#10 User is offline   thehemi
  • Normal
  • PipPip
Posted 14 June 2005 - 04:10 PM
Were the Honda motors OHC or pushrod?
Ford is using 3-valve OHC engines lately.
I have yet to heard of a pushrod 3-valve,
although I would be surprised if the idea
was not already attempted along the line.
#11 User is offline   faterotong
  • Active
  • PipPipPip
Posted 14 June 2005 - 04:16 PM
what's the difference between a OHC, OHV and a pushrod engine? I understand it's how the timing equipment is set up but in my uneducated mind, I always thought that OHV, OHC and pushrod were pretty much the same thing?
#12 User is offline   Kerryman
  • Allparian Ambassador
  • PipPip
Posted 14 June 2005 - 04:27 PM
All modern car engines are OHV. The valves are in the cylinder head over the pistons. How the valves are actuated is another thing. OHC is overhead cam, with the cam riding in the head and cam lobes acting directly upon the valve stems. This is the 4.7L Magnum. The 5.7L and 6.1L Hemi is an OHV with the cam sitting down low between the V and pushrods extending up to the valve rocker arms that in turn push the valves, hence the name pushrods.
#13 User is offline   faterotong
  • Active
  • PipPipPip
Posted 14 June 2005 - 04:33 PM
Thanks Kerry. That's much clearer to me now. :D
#14 User is offline   minkinc
  • Normal
  • PipPip
  • Location:Does anyone remember the movie Tron? Its like that ,but completely different.
Posted 14 June 2005 - 05:36 PM
Why does DCX need a V Twin engine? Is the CCV getting built? Are they Expanding into motorcycles?
#15 User is offline   HC_Earwicker
  • New
Posted 14 June 2005 - 05:39 PM
Now I am getting really confused :(!! The patent in question is for pushrod engines. Aren't the new 3.8/4.0 engines supposed to be OHC? As best as I can tell, there don't seem to be any new pushrod engines coming from Chrysler other than newer versions of the Hemi V8 - or am I completely missing something here?
- HCE
This post has been edited by HC_Earwicker: 14 June 2005 - 05:41 PM
#16 User is offline   longlivechrysler
  • The Negative Optimist
  • PipPipPipPip
Posted 15 June 2005 - 09:22 AM
skidsmadawg96, on Jun 14 2005, 01:13 PM, said:
Couldn't have said that any better myself.
Thanx for the info. I won't sleep tonight, but thanx either way... :unsure:
This is going to be one Heck of an autoshow season.
KyleD.
#17 Guest_hemidakota_*
  • Group: Guests
Posted 15 June 2005 - 09:24 AM
Dave or Stratus, we need to do some sticky on both subject - DCX PATENTS and DCX TRADEMARKS.
This post has been edited by hemidakota: 15 June 2005 - 09:54 AM
#18 User is offline   longlivechrysler
  • PipPipPipPip
Posted 15 June 2005 - 09:55 AM
Is there a way to keep them short though? I can see us shifting through the announcements as well as the following posts...
#19 User is offline   Trogdor02
  • Normal
  • PipPip
Posted 15 June 2005 - 11:52 AM
Not just a V-twin, but a V-twin that operates in a fairly nonstandard manner. I have no idea what the purpose of this could be. Is DCX trying to be like Honda and make motorcycles with four wheels?
#20 User is offline   Intrepidatious
  • Active
  • PipPipPip
  • Group: Supporters (L2)
Posted 15 June 2005 - 11:55 AM
If Dodge gets into motorcycles (and I don't include the Tomahawk), I'll sell mine now and get one!
Maybe the Tomahawk was used to gauge public reaction to an offshoot into cycles? Would be nice.
  • (19 Pages)
  • 1
  • 2
  • 3
  • Last »
