Beans, on Dec 28 2005, 05:27 AM, said:
Just a few weeks ago, someone posted that they found that exact fuse (same mfg — same part#) at Radio Shack for a couple bucks.
You might be able to find that post if you type the numbers on that fuse into the search engine. I think I remember the poster mentioning the numbers on the fuse.
Umm, yea, my post from last month. I must have read the thermal fuse wrong.
I just took the new (and blown) resistor block out of the car, the thermal fuse specs are:
144°C, 250V, 10A
That is the exact thermal fuse they sell at radio shack for $1.49. Well, except I think the radio shack version is 240V, which shouldn't make any difference. I even picked it up, to have on hand, just in case I wanted to try it.
But dummy me, I didn't pull the new resistor block first, I grabbed the old one still laying around. Since I thought it need a 30amp thermal fuse that I can't find, I left the 10 amp thermal fuse on the desk and took a regular 30amp fuse and soldered it over the blown thermal fuse to short it, but still supply some circuit protection. Put it in, works great again. Of course I look over the new resistor block I pulled and discover it has a 10 amp thermal fuse, so I could have used the radio shack version, I'll probably pop it in tomorrow night and give it a try.
The fuse block/PDC does NOT have a blower fuse, just a rear blower fuse, with relays for both so I'm assuming that the thermal fuse in the resistor block is the fuse protection for the blower motor. The rear blower is a 25amp fuse, but the front blower is a 10amp thermal fuse, that doesn't make sense, the front blower should draw more power than the rear.
I measured the resistance of the motor at 0.5 ohms, that seems low, in fact the lowest resister in the block was 0.5 ohms as well, if V=I*R, then the motor could draw as much as 12 amps, more than the thermal fuse rating. BUT, motors are inductive loads, so as the motor spins faster the resitance should go up. Anyone know a figure for the blower motor, other motors I've measured resistance on have been surprisingly low as well, so I'm not convinced that the blower motor is bad.
BTW, the air filter was rather dirty, but didn't look clogged, I blew it out with compressed air, some dust but not a lot. I'll try to get a fresh one tomorrow. The cut down airflow might reduce the cooling and raise the temp of the resistors, blowing the thermal fuse.
This post has been edited by Rick Anderson: 28 December 2005 - 02:01 AM
