hey everyone. I have a 1989 daytona shelby. I have no spark and no fuel. Pulled codes and is showing a 42 which is automatic shutdown relay. My question is where is that located at? I replaced the hall effect sensor thinking it was that before i pulled codes. oh well, could always use a spare! lol any help would be greatly appreciated. thanks.
| Guest Message © 2009 DevFuse | |
No Spark Or Fuel!?
#1 Guest_wiseguy30_*
Posted 18 February 2006 - 08:15 PM
#2
Posted 18 February 2006 - 08:52 PM
If it starts and runs, you will then have to check for corroded ASD relay contacts and verify power to the relay. If there is power to the relay and it runs doing the bypass to the coil positve, you might want to swap in another Relay, as the ASD relay may be bad.
#3 Guest_wiseguy30_*
Posted 18 February 2006 - 09:26 PM
thanks for the info. where is the asd located at? it is under the hood or in the car?
#4
Posted 18 February 2006 - 09:51 PM
#5 Guest_wiseguy30_*
Posted 18 February 2006 - 10:01 PM
Struts , on Feb 18 2006, 09:51 PM, said:
okay thanks again. there are four relays there. there are two on the drivers side fenderwell. then two side by side on the drivers side strut tower. thanks again.
#6
Posted 03 March 2006 - 09:11 PM
Here is a diagram I found for the relays you were asking about for a 1989 Daytona Shelby
if you still need them. Eddie
#7 Guest_wiseguy30_*
Posted 03 March 2006 - 10:56 PM
#8
Posted 04 March 2006 - 12:51 AM
(just copy and paste link in address bar if link doesn't work)
http://autorepair.ab.../bl195a-lib.htm
#9 Guest_wiseguy30_*
Posted 07 March 2006 - 09:19 PM
Sign In
Register
Help
MultiQuote
