I was given a 1969 Post Office Parcel truck. It runs well, stops well, but the steering box bearings are bad. I cannot find replacement bearings for this steering box.The box is a TRW with the numbers 302AS000-307 6 on the parts tag. Can anyone help me?
P200 Postal Truck (box Van)
#1 Guest_graphicsguy04_*
Posted 19 May 2006 - 07:28 AM
#2
Posted 20 May 2006 - 09:08 PM
graphicsguy04, on May 19 2006, 07:28 AM, said:
Try Lares out of Minnesota.
#3
Posted 12 June 2006 - 12:32 PM
Did you try the seals and sector shaft/ preload adjustments?
This is not an uncommon steering box.. used in Motorhomes, M300-M375, P200, P300 M880, W200, W300 with straight front axle forward steering.
There is a simple, "on vehicle" fix fro sloppy steering boxes, and leaking steering boxes....
you can find the simplified procedure here:
http://groups.msn.co...&ID_Message=614
Tom
