Hi all, I just recently bought my 1989 Dodge Daytona (2.5L SOHC, no turbo, sadly). It was a steal since the it had some minor electrical issues (which I resolved by pulling some new wires in) and some minor body rot on the floor.
I was driving home from work yesterday with it when suddenly it felt like I lost pressure in my brake lines. Luckily, I was able to use the e brake to get the car the rest of the way home (along with down shifting), where I discovered the line that leads to the passenger rear disc brake has a bad change over... which figures because from the pad to the change over is all new! Unfortunately, looks like I need to get the whole line replaced since it's pretty well rusted and taking off the change over will probably damage the metal line anyway. My question is if the mechanic doesn't charge me an arm an a leg should I go ahead and let him do the other lines or can I hold off on them until after christmas? All the lines have some rust scaling on them (dang New England winters), but other than that look none the worse for wear. I was going to run all new lines in a month anyway when I had more money and I had the car up on a lift anyway so I could cut out the rust and weld some new plates into it.
Thanks for any advice in advance.
[Update 1] Dropped the car off, got it back in 2 hours (!). Car was still on the lift so I was able to see what they had done. The mechanics had replaced both brake lines on the passenger side and the fuel line. Their reasoning on the brake lines was they had to replace at least one to get the new change over on, but the other one was in a similar condition that it probably would of popped the second they put fluid back in the system. The fuel line got done because it was actually leaking a little bit (very very slowly). In the end, just set me back $133 USD. Not bad at all, and I got a quote to do the remaining lines (about $250).
This post has been edited by Coder J: 30 November 2006 - 01:27 PM
Sign In
Register
Help
MultiQuote
