chuckt, on 22 October 2009 - 08:24 AM, said:
Here's my thoughts to get the van through the winter months. If I could tell how the upper mount assembly looks inside, I could drill a small hole into the chamber and inject grease to free up the binding. It would seem an easy task from above and the only thing to be concerned about is having a chip enter the chamber and foul the bearing or bushing. It would be a bigger pain to try entry from below (means I go through the wheel well side)and the lubricant may have a tendency to run if I do not seal the hole. Sounds interesting enough (and feasible) to try. I only need a cross section of what the strut looks like.
Hello,Here are a few ideas ,I just replaced the struts on my 01 caraqvan ,The upper mounts ,well actually the bearing was done,Total piece of junk,a bearing mounted between two pieces of plastic ,,now how could this take all the beatings from the road ????? plus the road salt and other foreging stuff gets caked up there ,so i packed them with grease all around ,its way better now ,but not a 100 percent ...if you need any more info ,e-mail me
thanks
