Okay, so I learned a very good lesson recently. When the blower motor goes, replace it ASAP... not wait two weeks. I ended up driving off the road the other day because I couldn't see through the windshield suddenly and tried to pull over. The problem there was where I pulled over ended up being a two foot drop into a rock lined ditch. The Daytona came through pretty good at first (actually corrected a small front end problem I thought would persist until I replaced the CVs), but a quarter mile later I started losing oil pressure. I quickly pulled off the road and found a fist sized hole in my oil pan where the plug should have been. Eeks!
The car is now sitting in my driveway (got it towed as when I jacked it up it hemorrhaged the remaining two quarts of oil out). I'm getting a new pan and gasket from Advanced Auto Parts, but I'm a little confused. Chilton shows the gasket as being a four piece affair requiring RTV around between the gaps, while the Advanced Auto Parts one appears to be one piece. Is this intended or should I just wing it and RTV the heck out of the pan edges before I bolt it up?
Before I forget, it's a 89 Dodge Daytona w/ 2.5L no Turbo (so sad).
