This is related to my pinging issue. I had found out that the EGR valve was not working. I checked the valve itself, the transducer & the solenoid. All check out. Even contnuitly from the PCM to the EGR. Here is the odd thing. The EGR will work when I unplug the connector from the solenoid. It throws a code but the valve works & my pinging stops. When I plug in the connector, the code clears & the EGR no longer works. Any ideas? Could this be a bad PCM? Is there any way to check it?
| Guest Message © 2009 DevFuse | |
EGR Problem
#1 Guest_patcal_*
Posted 07 July 2007 - 10:39 PM
#2
Posted 08 July 2007 - 09:30 AM
Did you replace the valve and the solenoid? They have to be done together as they are calibrated from factory to work together. Could be solenoid is faulty if you say valve works?
#3 Guest_patcal_*
Posted 08 July 2007 - 11:44 AM
bob22, on Jul 8 2007, 07:30 AM, said:
I did replace the whole EGR assembly. That is the only way I have found it sold. Solenoid checks out with the proper ohms & I tested it with a 9V battery & it clicked every time. This is why I am so stumped.
#4
Posted 08 July 2007 - 01:31 PM
manner that the ODB (on board diagnostics) determines an egr failure. After the engine has warmed up, the odb computer
will open the egr valve. This will cause a lean condition that the O2 sensor should detect. If the reading from the O2 sensor
does not change the odb assumes that the egr is failing to open and throws an egr code. My advice is to change out the
O2 sensor (upstream - before the catalytic converter) and see if that stops the pinging and the egr code. There may also
be a leak in one of the vacuum hoses or egr tubes that is causing additional air to get into the intake plenum.
Hope this helps,
Gerry G.
#5 Guest_patcal_*
Posted 08 July 2007 - 03:25 PM
Hope this helps,
Gerry G.
I have already replaced the O2 sensor before the catalyst. It failed on me a few weeks ago. I have also checked for vacuum leaks & was not able to find any. Thanks for the response.
#6
Posted 10 July 2007 - 05:17 AM
This post has been edited by t2erns: 10 July 2007 - 05:23 AM
#7 Guest_patcal_*
Posted 10 July 2007 - 07:07 AM
t2erns, on Jul 10 2007, 03:17 AM, said:
I have not modified anything. Totally stock & mostly original. I am thinking the problem is in the computer not sending the right signal. With the solenoid unhooked, it should allow vacuum to pass based on the backpressure at the time. When I plug in the solenoid, it never works. What do you think? Am I understanding how this works? Thanks.
#8
Posted 10 July 2007 - 09:21 PM
When the PCM energizes the solenoid, vacuum does not reach the transducer (the round part below the solenoid). Vacuum flows to the transducer when the PCM de-energizes the solenoid. When exhaust system back-pressure becomes high
enough, it fully closes a bleed valve in the transducer. When the PCM de-energizes the solenoid and back-pressure closes the transducer bleed valve, vacuum flows through the transducer to operate the EGR valve. De-energizing the solenoid, but not fully closing the transducer bleed hole (because of low back-pressure), varies the strength of vacuum applied to the EGR
valve. Varying the strength of the vacuum changes the amount of EGR supplied to the engine. This provides the correct amount of exhaust gas recirculation for different operating conditions. This system does not allow EGR at idle. A failed or malfunctioning EGR system can cause engine spark knock, sags or hesitation, rough idle, engine stalling and increased emissions.
EGR gas flow test:
.connect a vac hand pump to the EGR valve vac motor. w/ engine running at idle slowly apply vac, engine rpm should drop or engine may stall.
EGR system test:
allow engine to run to fully warm-up (ect temp over 150 deg F) with transmission in neutral and throttle closed, abruptly accelerate the engine approx 2000 rpm but not over 3000 rpm. the egr stem should move when accelerating the engine (groove of the egr stem should change) repeat test several times. if the stem moves, the control system is working normally.
#9 Guest_patcal_*
Posted 11 July 2007 - 05:42 AM
Thanks for the reply. I have followed those procedures. The valve works fine. When I apply vacuum the valve opens & stays open as long as vacuum is maintained. This no mechanical problem with the valve. When I do the second test of blipping the throttle, is when it fails. Absolutely no valve movement & have confirmed no vacuum being let through the solenoid. The computer is not signaling the EGR at any time to de-energize. That is why the EGR works with the solenoid connection unhooked.
Pat
#10
Posted 11 July 2007 - 09:44 PM
#11 Guest_patcal_*
Posted 12 July 2007 - 05:21 AM
Pat
#12 Guest_patcal_*
Posted 12 July 2007 - 10:26 AM
Pat
#13
Posted 12 July 2007 - 11:45 PM
patcal, on Jul 12 2007, 11:26 PM, said:
Pat
pat as long as the wirings are intact (egr solenoid to the pcm) i guess it will not throw the code if the ground wire is grounded the fact that the said wire is shorted to ground the solenoid wont turn-off even if the pcm is cutting it's ground (bec ground is always there that keeps the solenoid energized) it's just my 2 cents if its an older car (newer models have some rationality checks for each circuit).BTW have you checked if you're getting some lean codes, is your scanner capable of reading fuel trims, injector pulse width and oxygen sensor readings so we can diagnose it further? is this car the one in your signature, what's the engine size, i'd like to check if there's a service bulletin for this car.
This post has been edited by t2erns: 12 July 2007 - 11:49 PM
#14 Guest_patcal_*
Posted 13 July 2007 - 05:17 AM
t2erns, on Jul 12 2007, 09:45 PM, said:
Yes, it is the car in the picture. The engine is the 2.0L & the car has an auto tranny. It has 93500 miles on it. Yesterday when I was testing various things. I unhooked the connector at the EGR. I checked for continuity to ground. I had no continuity on number 60 but did on 6 . Even when I unplugged the connector at the PCM I had ground continuity at both the PCM end & EGR end. Is that supposed to be that way. I thought the ground was through the PCM so there should be no ground in either wire going to the solenoid. Am I thinking correctly on this? Even when I unplug the ASD relay which is part of circuit 142, I get a ground at that wire.
My scanner is capable of reading fuel trims & O2 readings but I do not think it does injector pulse. It is a Actron CP9145.
I wanted to say, I really appreciate all your help. I think you have gone above & beyond what most forum dwellers would do.
Pat
#15
Posted 13 July 2007 - 05:47 AM
"wanted to say, I really appreciate all your help. I think you have gone above & beyond what most forum dwellers would do".
the signature have your answer... cheers
This post has been edited by t2erns: 13 July 2007 - 05:49 AM
#16 Guest_patcal_*
Posted 13 July 2007 - 06:12 AM
I will recheck when it gets light out. I am almost positive that it was cavity 6 & not 40 that was grounded with both PCM & EGR connectors disconnected. On my diagram from alldatadiy, it says cavity 40 is EGR Solenoid Control & cavity 6 is ASD Relay output.
#17
Posted 13 July 2007 - 06:56 AM
#18 Guest_patcal_*
Posted 14 July 2007 - 10:13 AM
Pat
This post has been edited by patcal: 15 July 2007 - 07:28 AM
#19
Posted 15 July 2007 - 10:34 PM
#20 Guest_patcal_*
Posted 16 July 2007 - 05:17 AM
t2erns, on Jul 15 2007, 08:34 PM, said:
Well, I am about 90% sure. Since I do not know how the PCM actually stops power to the solenoid I have a little lingering doubt. It really is all it can be anymore unless something outside the PCM is not reading right & giving the PCM faulty info. Thanks for your help. Now I got to try find a part number match for my PCM. So far no match on Google.
Sign In
Register
Help
MultiQuote
