NewsState of the Hemi, 2022 • Even Demon test cars live to be broken • FCA racks in NEMPA awards
2002 PT cruiser /overheating
Discussion in 'PT Cruiser' started by geraldg, Apr 22, 2017.
  1. geraldg
    geraldg Active Member Ad-Free Member
    663
    Was looking at one and it said it overheated on long drives, Don't know what engine but could it be the head gasket ?
  2. Doug D
    Doug D Virginia Gentleman
    1,437
    Could be a scaled up radiator, stuck thermostat or just low on coolant (don't overlook the simple stuff). Head gasket is a possibility as well. As I recall the PT's had either a 2.0L or 2.4L engine.
  3. ImperialCrown
    2,314
    Although the 2.0L is listed, all U.S. PTs that I have ever seen are 2.4L.
    A coolant sample can be tested for the presence of CO2 gas, which would be a likely head gasket combustion leak into the water jacket. Diagnose first.
    Doug D likes this.
  4. dana44
    dana44 Well-Known Member Ad-Free Member
    1,340
    Yeah, they don't heat up unless a couple of problems have occurred. Low on fluid, as in the overflow is good, but the radiator level is low, so when cooled down, pop the cap and see what it is looking like. Head gasket leaks pushing the fluid out of the engine and into the overflow and overheating, cooling fans not coming on at all, and yes, blocked radiator.
  5. voiceofstl
    voiceofstl Member
    180
    Make sure BOTH electric radiator fans are working.
  6. ImperialCrown
    2,314
    When the present owner says that it overheats on long drives, is he talking about sustained highway driving (where the cooling fans wouldn't be used)? Or can it overheat while in 'stop and go' type traffic (where the cooling fans might be needed)? I believe that this is a single cooling fan with both high and low speed control.
    Are there any other 'overheat' symptoms besides an elevated temperature gauge?
  7. geraldg
    663
    How hard is it to hot wire the fans so they run all the time, if that is the problem.
  8. ImperialCrown
    2,314
    You don't really want to do that. Diagnose first.
    valiant67 likes this.
  9. geraldg
    663
    If I buy it and have to drive it home I would like this as a option. I would find out more but if the fans relay is bad this would help. I also know that to keep a car from overheating you can use the heater because basically it is another radiator.
  10. ImperialCrown
    2,314
    If you can drive home at speeds of 25 mph or above, then it won't matter if the radiator fan is running or not. The incoming air will cool the radiator sufficiently.
    A heater core can disperse some heat, maybe enough to keep the temp safe.
    If the head gasket is blown and pushing coolant out of the radiator and into the reservoir, then it will overheat no matter what.
  11. geraldg
    663
    If I go to check it out and find it has a blown head gasket I will walk away, to much work.
  12. chuzz
    chuzz Active Member
    400
    If you ever had to replace the water pump and timing belt on one of these, you'd never buy another one. I know I sure won't.
  13. geraldg
    663
    After thinking it over I decided to pass on the car, thanks for all the help.
  14. ka9yhd
    ka9yhd Member
    209
    A friend rented an early PT and it had the 2.0 Liter, and it was under powered to the point of being scary getting on an expressway. Later on he bought a used PT which had the 2.4 plenty of pep.
  15. dana44
    1,340
    I still wish they would have dropped a 3.3/3.8 under the hood. The turbo was nice, but I like the extra cylinders and beef of a V6 over the 4 cylinder 2.4. Although porting the head did help quite a bit.
