NewsNew Compass shipping soon • Compass: mpg, $$$ • Demon’s drag suspension: better launches
88 Daytona Shelby Z Lemons Race Car
Discussion in 'Daytona and Laser' started by Naking, Feb 8, 2017.
  1. Naking
    Naking Member
    I own a 88 Daytona Shelby Z that I raced at Barber last weekend in the 24 hours of Lemons endurance race. We battled over heating issue all day until she finally got to hot and started knocking. I was looking for some good ways to keep her cool.
    I also would like to try and get more power out of her once i can keep here cool. We want to try and get more boost out of the turbo. I am up for any help.
    thanks,
  2. Bob Lincoln
    Bob Lincoln "CHECK FAULT CODES" Level 2 Supporter
    2,470
    Those will be conflicting goals to some extent. Cooling will get more power, but boosting the turbo will generate more heat.
    Is the intercooler setup intact and working?
    Some have reported success by reworking the fascia with a shield behind it to direct airflow better onto the radiator.
  3. ka9yhd
    ka9yhd Member
    192
    Bob please correct me if I am wrong but I think cooling systems are somewhere around 40 % effective at cooling.
    I have a friend who owned a Mitsu Eclipse and he saturated the cooling system and the car over heated with an extended trip at 100 + mph. He had the turbo glowing a dull red color.
    I agree the more airflow through the radiator the better by removing any obstructions to the airflow and maybe some sort of ducting other ways of guiding more air into the radiator. And maybe some vents in the hood to let the hot air out so as to not have all the incoming air not have an escape route which might cause a lose in traction at high speeds.
    Redline makes a water wetter product to improve cooling which is either added or used in place of coolant.
  4. moparguru
    moparguru New Member
    Have you ventured over to the Turbo-Mopar.com Forums where we (other turbo Mopar enthusiasts) hang out for advice and other tech help? From 10 sec Omnis and Daytonas to stock and raced turbo Minivans, you should be able to find help there.
  5. CudaPete
    CudaPete Active Member Ad-Free Member
    189
    Change to a 180 deg thermostat. Stock is 195. This will help keep oil temp down too. Use a Diesel rated oil.
  6. bamman
    bamman Part Connoisseur
    24
