NewsNew Compass shipping soon • Compass: mpg, $$$ • Demon’s drag suspension: better launches
'94 LeBaron LE Sedan - Front sway bar diameter?
Discussion in 'EEK! - Every Extended-K Car' started by goair99, Feb 15, 2017.
  1. goair99
    goair99 Member
    27
    What is the diameter of the front sway bar on a base LeBaron LE sedan w/3.0?
    Rockauto has 1", 1 1/16", 1 1/8" and 7/8" listed! WTF???
    I am going to have them replaced...
  2. manybrews
    manybrews Member
    9
    your best bet is to measure it with a caliper, because I doubt anyone will have the knowledge as to which trim came with which sway bar.
    Bob Lincoln likes this.
  3. goair99
    goair99 Member
    27
    The senior members usually know questions like this. Just waiting for a response.
  4. Bob Lincoln
    Bob Lincoln "CHECK FAULT CODES" Level 2 Supporter
    2,470
    Same here. I would measure with calipers. If not available, wrap a string around the bar, mark the circumference, and then measure it and divide by pi (3.14) to get the diameter.
  5. ImperialCrown
    2,134
    Are you replacing the inner/outer bushings? I only have Mopar part #'s that might cross-reference, I don't have sizes.
    If this is truly the standard suspension, the stock sway bar is Mopar part # 5272208, the inner bushings are # 5272219 and the outer bushings are # 5272214.
  6. goair99
    goair99 Member
    27
    Thanks for your research! I am replacing both because of a knocking sound from the front. I had new Monroe Quick Struts installed and the knock is not as bad, but I am suspecting it's the sway bar bushings...
  7. ImperialCrown
    2,134
    They do wear. The outers will clunk over bumps (the normally round bushing hole becomes oval) and the inners can squawk and creak over bumps. The service manual says not to lube noisy rubber bushings. Petroleum greases will attack the rubber, but silicone greases are more rubber friendly (only if you need it).
  8. neon98rt
    neon98rt Member
    16
    Wait where did you find monroe quick struts for a lebaron??? I only could find struts.
  9. manybrews
    manybrews Member
    9
    Rock auto. They'll have everything.
  10. neon98rt
    neon98rt Member
    16
    show me the link for a 90 and i will be your best friend. Maybe there is some for newer years.
  11. goair99
    goair99 Member
    27
    rockauto.com Monroe part# 171819L and 171819R $91.36 each and in stock...
  12. manybrews
    manybrews Member
    9
  13. goair99
    goair99 Member
    27
    Last try for the sway bar diameter... LE 3.0 sedan??? Very hard to measure with a string.
  14. Bob Lincoln
    2,470
    Measure with a strip of paper, then. It won't stretch. Just wrap it around and mark it to get the circumference and divide by Pi.
  15. goair99
    goair99 Member
    27
    Ok, will give it a try and get back with an update.
