NewsNew Pacifica trim to hit sweet spot? • Does the Demon stop faster than the Camaro ZL1? • More Waymo Pacificas; public to test
Centering the Engine
Discussion in 'PT Cruiser' started by chuzz, Mar 23, 2017.
  1. chuzz
    chuzz Active Member
    383
    Anyone know the torque specs for the upper and lower mounts? According to the Autozone website, it's 85 ft. lb. That seems light to me. Can anyone confirm?
  2. pt006
    pt006 Member
    372
    85 is correct for the large bolts. 18 mm socket, I think. The 'pencil strut' is a vertical brace that bolts onto the outside threads of the rearward bolt of the lower torque strut. The torque for these nuts is 43 ft-lbs.
  3. chuzz
    chuzz Active Member
    383
    Thanks, pt006. That's what I used and all is well.
