NewsWho makes the “most American” vehicles? • Meet the upgraded 2018 Durangos • Rumored Challenger Hellcat Widebody: it’s real
Charging problem on 2006
Discussion in 'PT Cruiser' started by ptcrooser, Dec 14, 2016.
  1. ptcrooser
    ptcrooser Member
    Looking for some advice.
    My PT is not charging properly. I changed the battery (mostly because it was old anyway.) And is have had a bench test done on the alternator and the guy says it is fine.
    When idling is it cranking out 13 - 13.5 volts, but when there is a load on the system the out drop down to 10 or 11.
    Any have any advice one where to look next?
    Thanks!
  2. Doug D
    Doug D Virginia Gentleman
    1,483
    If you have a multi-meter (they run about $15-$20) the battery voltage at rest (engine not running) should be 12.6 volts (6 cells x 2.1 volts each). With the engine running the voltage should be over 14 volts (14.3-14.4 volts). Anything less points to the alternator not producing a sufficient charge.
    Before replacing the alternator though, I would definitely clean the battery posts and cables, and then measure the voltage again. A film can build up over time and create resistance and limit voltage.
    Perhaps Imperial or Bob Lincoln will post a reply. They are a bit more knowledgeable on this. Bob's an electrical engineer and Imperial is a former Chrysler mechanic. I just know the basics. I don't think a bench test is a sufficient test.
    Most auto parts retailers (AutoZone, Advance Auto, NAPA) will test the charging system for no charge.
  3. AllanC
    AllanC Active Member
    329
    I would suspect one or more failed diodes in the alternator. AT low electrical low the system can manage but at higher load / engine rpm, it cannot produce desired electrical current and voltage.
    Bob Lincoln and Doug D like this.
  4. ImperialCrown
    2,377
    Welcome to Allpar. Any fault codes or battery light coming on? If your charging voltage falls below normal, there is a alternator/regulator/wiring/connection problem that has to be located and corrected.
    There was also a PCM software flash addressed in TSB # 18-007-07 for P0622/P063A fault codes:
    http://www.dixie-electric.com/tsb/TSB_852.pdf
  5. Bob Lincoln
    Bob Lincoln "CHECK FAULT CODES" Level 2 Supporter
    2,837
    That was my experience once. I confirmed it by measuring a fast drop in battery voltage with engine off. By morning it would barely crank and not start. Was 13.3 volts at idle when it was running.
