NewsFiery finish for Beckman – Updated with points • The official vehicle of Canada Day • Ram leaving “big rig” look behind?
Code P0128 2012 Durango 3.6
Discussion in 'Grand Cherokee, Durango, etc' started by Dirt_mopar99, Jun 15, 2017.
  1. Dirt_mopar99
    Dirt_mopar99 New Member
    Hi! I have a 2012 Durango with a 3.6. I keep getting code p0128 coolant code. What to try? Theromstat or coolant sensor? Thanks in advance!
    2,374
    The heater and temp gauge works OK? I would try the PCM flash that is addressed in TSB # 18-110-16. It fixes a slew of false fault code sets including P0128.
    It should be covered under your 8/80 extended federal emissions warranty:
    tsb_wk2_1811016.pdf
    Crawdaddy likes this.
