NewsWhat’s special about the Demon? • Demon has a freakin’ TransBrake • Pritchett’s Challenger Drag Pak isn’t a Demon
Crankshaft position sensor leak
Discussion in 'PT Cruiser' started by mainones, Jan 18, 2017.
  1. mainones
    mainones Member
    3
    I have a 2001 PT Cruiser base model I am wondering if it common to have the crankshaft position sensor leak where it is attached to the engine? Mine seems to be and was considering removing it and replacing the o-ring. Anybody else done this?
  2. Bob Lincoln
    Bob Lincoln "CHECK FAULT CODES" Level 2 Supporter
    2,517
  3. mainones
    mainones Member
    3
  4. ImperialCrown
    2,204
    Probably engine oil. The CKP sensor is above the oil filter adapter which is a more common leak. So is the oil pan gasket.
    Because the sensor is mounted at the rear of the engine, oil can blow around and look like something else is leaking.
    If you are not sure of the leak source, it may help to degrease and rinse the area to do a visual leak location test.
  5. dana44
    dana44 Well-Known Member Ad-Free Member
    1,296
    Agree with cleaning the area before replacing the O-ring, unless it has been removed recently it is extremely rare that it would leak.
