NewsThis really is the 2018 Wrangler “JL” • Red vs black keys: Real-world Hellcat performance • Windsor loses Transport
Engine start stop for JL Wrangler
Discussion in 'Mopar News and Rumors' started by corpcow, Feb 15, 2017.
  1. corpcow
    corpcow Member
    67
  2. JKU12
    JKU12 Active Member
    3,338
    I believe JGC improved about 1-2 mpg combined from 2015 to 2016 depending on the various trims. I don't think it was all because of ESS though.
  3. link3721
    link3721 Needs More Jeep Level 2 Supporter
    389
    It helps with city mileage, but I don't think the MPG rating (EPA cycle) accounts for it yet. I'd imagine an mpg or two in city driving.
    UN4GTBL likes this.
  4. Chase300
    Chase300 Member
    467
    I had it in a JC V6. Worked as designed. They are not invisible, you know it, but it fired up quickly and I could see getting use to it pretty quickly.
    guyverfanboy and UN4GTBL like this.
  5. Rick Anderson
    Rick Anderson Active Member
    1,985
    I rode in a Mercedes CUV with Start/Stop, its very noticeable in the Mercedes. I think there is just no way around it, and engine stopping and starting is going to be noticeable.
    Probably just something you get used to. It should come with the option to disable the feature, so if your overdue on a spark plug change and the engine isn't starting easily, you don't end up blocking traffic or being frustrated with each start taking a long time.
    The ZF transmissions have an option in their design to add an accumulator and the stored pressure/energy in the accumulator can be used to start the vehicle moving via the transmission being turned by the accumulator, then engage the engine and start as the vehicle accelerates for the engine to take over. I would think this "might" make for a smoother start up, provided the engine is going to start easily and there is enough energy stored in the accumulator, it could be very rough, and even stalled and lurch to a stop if the accumulator runs out of energy before the engine has started well enough to take over and move the vehicle.
  6. wilbur
    wilbur Member
    440
    My wife has it in her Encore. Other than wanting to rip it out for the first month, she has gotten use to it.
    A friend has start/stop in his '16 F150 and just presses a button on the dash to shut it off.
    Works well otherwise and pretty seem less.
    I am thinking there will either be a button to turn it off or automatically turn off when you are in off road situations in the new wrangler... (I would hope)
    Wil
    guyverfanboy likes this.
  7. UN4GTBL
    UN4GTBL Active Member
    1,687
    There is a button to disable it in the Cherokee & Grand Cherokee, so I would think there would be one in the new Wrangler.
    Having said that it resets with every ignition cycle, so it won't stay off until you turn it back on.
    As well, it's just on the 3.2 and 3.6L versions of the above vehicles IIRC
  8. redriderbob
    redriderbob Mopar Guru! Supporter
    6,138
    2018 Jeep Wrangler / Wrangler Unlimited JL
      • Production startup November 2017 (production moving to Toldeo North Assembly Plant)
      • All-new "JL" Wrangler
      • New: First model year for the all-new "JL" generation
      • New: 2nd generation ZF 8-speed transmissions
      • New: 2.0L Hurricane engine (with new 850RE transmission)
      • New: 3.0L VM Diesel engine for North America (with new 8HP75 transmission) (possible delay until 2019 model year)
      • New: 3.6L Pentastar upgrade engine with Electronic Stop/Start (with new 850RE transmission)
      • New: 8.4" next gen navigation radio
      • New: Interchangeable soft top / hard top
      • New: True 3-piece hard top
      • New: Power soft top (will fold like the Liberty skyslider)
      • New: Available glass panel for hard top
  9. Mike V.
    Mike V. Moderator
    15,133
    This shouldn't surprise anyone... it is coming, across the board.
    Mike
  10. link3721
    389
    I still don't understand why anyone would turn ESS off (excluding off-road, which probably would trip the conditions to disable it). Had it in a rental Cherokee and wasn't bothered at all.
    guyverfanboy and xjgary like this.
  11. UN4GTBL
    1,687
    It's different
    guyverfanboy and GasAxe like this.
  12. Rick Anderson
    1,985
    What little I've seen, it bothered me, enough to turn it off and at least not try to give it a chance and try to get used, no I would try to get used to it. I can see some being endlessly annoyed by it and want to shut it off.
    It might be better for the car and even mileage if you're in very heavy traffic jam that your stopping and starting every 10 seconds, probably a good idea to shut off the ESS.
    Don't forget people will own these cars for a decade, the engine might have a malfunction that hasn't been repaired yet, and it be hard to start. I can imagine being in heavy traffic and every time I come a stop and the motor takes 10 seconds of cranking and stalls if shifted into gear too quickly. Shutting off ESS would be a god send, so I can get to the shop and get the motor fixed within the next couple of hours and not block traffic behind me.
  13. xjgary
    xjgary Member
    127
    My daily driver is a Prius. I don't even notice it anymore, but first time passengers panic and tell me that my engine just quit . Or they remark about how quiet it is at the stoplight. But it always works fine.
  14. Roger Mac
    Roger Mac New Member
    Great info, confirms most of the rumors so far.
    Any word on availability of manual transmission or integral metal roof version?
  15. redriderbob
    6,138
    Yes, manual will be back... many of the mules around are the 6-speed manual.
