NewsBehind the Jeep/Ram spinoff chatter • Demon to beat Exorcist? • FCA profits as buyers drop sedans
Factory radio issue
Discussion in 'PT Cruiser' started by Rags Maddox, Mar 1, 2017.
  1. Rags Maddox
    Rags Maddox New Member
    I haven't posted in awhile, but wanted to see if anyone's had a similar issue. I just had to replace the PCM in my sister's 2003 PT GT for the 2nd time. Afterward, everything is working except the factory radio. It's not turning on at all. I was wondering if the 2 things are related, or if just by coincidence, there's an issue with the radio now...
    2,248
    Check both fuses? The radio is turned on and off by the communications bus, but if that was down, you would have other symptoms. It wouldn't be related directly to the PCM replacement, but possibly something opened or shorted during the changeout? Was the battery disconnected during the PCM service?
  3. Rags Maddox
    I wasn't involved with the PCM swap, but after I posted, my sister said the 2nd time she drove the car, the radio turned on like normal... She also said with the new Syked stage 1 flashed PCM, the car has never felt quicker lol. It had a standard Stage 1 PCM previously.
