NewsNew Pacifica trim to hit sweet spot? • Does the Demon stop faster than the Camaro ZL1? • More Waymo Pacificas; public to test
Fuel filter & lines.
Discussion in 'PT Cruiser' started by mr2tim, Mar 29, 2017.
  1. mr2tim
    mr2tim Member
    7
    I want to pass along some information I've gathered during my recent fuel pump replacement on my wife's 05 which is a non-turbo.
    There is a filter attached to the bottom of the fuel pump, many of us call this a "fuel sock".
    There is no other fuel filter in this car.
    There is a connector, located on the firewall almost directly in front of the glove box, that is easily disconnected to confirm if your getting fuel from the pump. Be sure to have a rag there when you key the ignition to ON which activates the fuel pump.
    This location is also the most convenient place to test fuel pressure. The spec is 58lbs.
