NewsNew 500L launched • Updated: Engine recap • Mopar dominates Funny Car, sets records
Jeep Cherokee refresh: styling direction?
Discussion in 'Mopar News and Rumors' started by oh2o, Jun 4, 2016.
  1. james.mooney.
    james.mooney. The Poster Formerly Known As "Bethlumboy"
    1,462
    Has anyone heard any possibility of the Cherokee getting the Pacifica's PHEV system? It seems like the next logical application, other than a Chrysler CUV ("RA" or KL-based).
    If they do a Cherokee PHEV, would it make more sense to use the 3.6 V6, or to adapt it to work with the Tigershark or Hurricane 4 (since it is a smaller vehicle)?
  2. redriderbob
    redriderbob Mopar Guru! Supporter
    8,040
    The DRL's on the 2018 Cherokee retain the same shape. The hi/low beam projector is moved up to the same housing as the DRLs. The projector's are moved to the outside of the lamp. Where the headlight is in the current Cherokee is replaced with a turn signal. The fog light's stay in the same spot however become like the Chargers three led layout. Turn signals will also be LEDs.
  3. Erik Latranyi
    Erik Latranyi Well-Known Member Level III Supporter
    8,460
    Don't forget, this is a refresh, not an all-new model.
    The refresh is mostly cosmetic. The plant is retooled.
    Since most everything on the Cherokeee stays the same, it makes sense to start and build the old design so the equipment can be tweaked properly before starting on the new bodystyle.
    valiant67 and dakota21 like this.
  4. BobbiBigWheels
    BobbiBigWheels I'm likely at work... Ad-Free Member
    2,005
    I understood every part of your comment except the bolded part. What kind of shape does the headlight retain?
  5. freshforged
    freshforged Active Member Level 2 Supporter
    1,185
    Using the old model to troubleshoot the new line?
  6. UN4GTBL
    UN4GTBL Active Member
    1,810
    More of a conventional headlight design/shape
  7. redriderbob
    8,040
    2018 Jeep Cherokee
      • Production startup August 28, 2017 (Belvidere plant)
      • Mid-cycle refresh, revised front design, changes to rear fascia
      • New 2.0L "Hurricane" engine (2018 or 2019 model year)
      • Supposedly 3.2L to be dropped for 3.6L engine.
  8. redriderbob
    8,040
    The projectors for the hi/lo beam is pushed to the outside corner of the headlights.
    BobbiBigWheels and UN4GTBL like this.
  9. redriderbob
    8,040
    Correct. Also Cherokee is the most sold Jeep. Have to keep dealers supplied.
    UN4GTBL likes this.
  10. oh2o
    oh2o Moderator Level III Supporter
    3,261
    Roughly speaking, overall headlamp housing shape, current on top, new on bottom, see attached.
  11. UN4GTBL
    1,810
    Makes sense, as I would think that the hood and fenders would stay the same
  12. dakota21
    dakota21 Member Supporter
    173
    That makes sense. As an industrial engineer (co-op), I can still see the changeover to the refresh being a potential headache after just setting up for the old equipment. But nothing can replace good troubleshooting in a new environment.
  13. Deckard_Cain
    Deckard_Cain Member
    229
    And when will they show the facelift to the public? Is there an ETA for that?
    From what oh2o has attached, the new headlights will be similar to the Compass headlights.
  14. Archknight
    Archknight Member
    165
    I'm looking forward to this, since I can't wait anymore on a new car and I was holding out to see what was coming out of Chrysler. I guess I'll have to settle for a 2018 Cherokee.:):):)
    cdjr77 likes this.
  15. oh2o
    3,261
    Quite different actually.
    AlfaCuda, Mike V. and dakota21 like this.
