NewsNew Compass shipping soon • Compass: mpg, $$$ • Demon’s drag suspension: better launches
Made a change to the Red Wagon
Discussion in 'XJ Cherokee, Liberty, Nitro' started by poorboy_616, May 7, 2016.
  1. poorboy_616
    poorboy_616 Mr. Fixit Level 2 Supporter
    31
    So... This happened.
    Also, finally picked up a Winch bumper and a Winch for the front of the Red Wagon. Heavy beast, but not as bad as the rear assembly. Cutting sheet metal on an otherwise clean, straight vehicle is nerve wracking, to say the least!
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    I will be installing aftermarket flares at some point, which will cover the ugliness of the fender cuts.... Once the metal started flopping, keep the cuts straight was a huge challenge. They're not great, but that will be covered up later.
    Shane Estabrooks likes this.
  2. MPE426HEMI
    MPE426HEMI Active Member
    2,383
    That looks awesome, man.
    poorboy_616 likes this.
  3. Shane Estabrooks
    Shane Estabrooks Member
    220
  4. poorboy_616
    31
    The Winch got a little work out this winter when my Neighbor needed a little help out of his driveway. *Just* enough incline to make getting from Garage to street nearly impossible when you can't get a run at it. Yes, he does have 4wd and good tires, just needed a little help once it turned into an Ice Rink.
    Pretty darn good for a $300 Harbor Freight special.
    AvengerGuy and Shane Estabrooks like this.
