NewsNew Pacifica trim to hit sweet spot? • Does the Demon stop faster than the Camaro ZL1? • More Waymo Pacificas; public to test
PCM issue?
Discussion in 'PT Cruiser' started by chris wilson, Apr 5, 2017.
  1. chris wilson
    chris wilson New Member
    Hello everybody!
    New to the forums and I'm hoping somebody could give me hand here. I have interesting issue..
    My 2004 PT Cruiser stalled on me a few weeks ago..I went to do the key dance (which I've done successfully many times before) nothing happens..dash lights up..but test never shows a error code or even show the "done" sign. I borrowed an OBD reader the next day and plugged it in. The car actually turned over and I saw the reader power on. About 5 min later the car stalled while I was sitting in place. Tried key dance nothing..even the OBD reader wasn't on powering on this time around.(no power to the connector?)
    I tested my battery, fuses, and relays..everything looked. As of right now it's a no crank/no start..I'm guessing a bad PCM? Do the chipped grey keys have a life span?
    2,247
    Welcome to Allpar. I would check for 12 v powers (ignition and battery) and grounds at the PCM connectors and at the DLC connector first.
    The gray SKIM key is a passive RF transponder. They can fail, but don't have any particular life span. Is there a 2nd key you can try? A bad SKIM key would likely light the yellow SKIM light or red VTSS light in the instrument cluster at a no-start.
    See p. 368 for the PCM-C1 connector pin-out and p. 354 for the DLC connector pin-out here:
    http://oskin.ru/pub/chrysler-dodge/...2004_PL_Neon/18623-pl-powertrain_sgmldiag.pdf
    I would not condemn the PCM without further diagnosis. Since it came back to life and then died again, it sounds more like a failing connection.
    djsamuel and valiant67 like this.
  3. Gerry G
    Gerry G Member
    89
    Check the ground strap connections in the engine bay; there are number of them. Make certain they are corrosion free. How old is the battery; you noted you tested it but sometimes batteries test good.
  4. chuzz
    chuzz Active Member
    383
    In reference to what Gerry stated, remove the battery and check the grounds there on the driver side fender. This is a known problem area on the PT's, due to corrosion caused by the battery. If the vent caps leak the fumes out, they can corrode the connections and sometimes they just break off.
  5. chris wilson
    Thanks fellas! I'll check the grounds. I just bought a new battery 3 weeks ago.
