NewsWho makes the “most American” vehicles? • Meet the upgraded 2018 Durangos • Rumored Challenger Hellcat Widebody: it’s real
PT Cruiser reliability - how does it compare?
Discussion in 'PT Cruiser' started by mkaresh, Mar 2, 2007.
  1. mad al
    mad al Guest
  2. mkaresh
    mkaresh Member
    3
    We've updated results for the PT Cruiser. In terms of repair trips per 100 vehicles per year:
    2001: 95, about average, higher than before but now consistent with...
    2002: 101, about average
    2003: 90, about average
    2004: 152, worse than average, and likely not accurate based on results for the other three years
    In all four cases sample sizes are small, and these results are asterisked and visible only to participants on the site itself.
    A big thanks to everyone who has been helping. We'll have further updates in August and November. With more participants we can provide full results for the above years and include the others.
    Chrysler PT Cruiser reliability comparisons
  3. mkaresh
    mkaresh Member
    3
    We'll start previewing the next results to participants in about a month. Additional participants would be very helpful. 195 signed up so far. 200 soon?
    Car reliability research
  4. shoop2it
    shoop2it Member
    mine just crossed 100k miles, and only prob is the engine surges when slowing down and sometimes it kills out. no codes, and after replacing the timing belt and water pump (just did it since it was recommended, and hoping that it may fix the problem as well) and a guy at advance told me about his doing the same thing. Just told me to pull out the sensors in the throttle body, and clean em good, and do same for the throttle body and should fix it.
    going to try it tomorrow, to dark outside to do now lol
  5. mkaresh
    mkaresh Member
    3
    Any success with this? My wife's 2002 doesn't have this particular problem...yet.
    199 PT Cruiser owners now signed up. A good start, but more are needed to provide precise results for all model years.
  6. davnau
    davnau New Member
    My 2007 convertible has had two problems:
    1. Lower control arm bushing replaced at 30K miles.
    2. Have had to replace the trim panel for the power seat switch six times, all under warranty. It's a bad design, in that getting in and out of the car normally breaks it after a few months. It's held on by only three plastic posts and they break. Non-power seat trim panel is one piece and doesn't break.
    Rest of the car has been fine, at 34k miles now.
  7. mkaresh
    mkaresh Member
    3
    Ah, yes, the control arm bushings. At least yours failed under warranty.
    We've updated results for the PT Cruiser to include owner experiences through June 2008. In terms of repair trips per 100 vehicles per year:
    2001: 97, about average
    2002: 133, about average
    2003: 78, about average
    These results aren't consistent from year to year, probably because in all four cases sample sizes are small.
    A big thanks, once again, to everyone who has been helping. We'll have further updates in November and February. With more participants we could provide more precise results and include all model years.
  8. Jamspeed
    Jamspeed Guest
    I have a 2002 PT Limited, we got used with low miles in 2004. Only big repair I remember was AC at around 60K. We had an extended warranty thankfully! I can try to look into other minor repairs over the years, but the PT has been very reliable.
  9. tpriester13
    tpriester13 Guest
    I added my recently purchased 2002 PT Cruiser........purchased from family member(they were second owner), so will get as accurate information as i can...
  10. dana44
    dana44 Well-Known Member Ad-Free Member
    1,350
    I just went over 88K on mine, did a 350mile trip one way, cruised most at 85mph through the desert, got 28.4mpg with the AC on (had my daughter with me, she likes cooler temps when driving), and have used 2 quarts of synthetic oil in the past 9,000miles.
  11. mkaresh
    mkaresh Member
    3
    Thanks, guys.
    We'll have updated results next month. Are few model years are just five or six responses short of the minimum for a full result, so additional participants would be very helpful.
  12. mkaresh
    mkaresh Member
    3
    We've updated results for the PT Cruiser to include owner experiences through September 30, 2009. In terms of repair trips per 100 vehicles per year:
    2006: 17, better than average
    2004: 142, worse than average
    2003: 61, better than average
    2002: 159, worse than average
    2001: 88, better than average
    These results are perhaps the least consistent from year to year of any model in the survey, probably because in all five cases sample sizes are small.
    A big thank you, once again, to this forum and everyone who has been helping. We'll have further updates in February and May. More participants needed to provide more precise results and include all model years.
  13. johnsr
    johnsr Guest
    bought my son,s new in 2002 and havent had any problems until now , it is overheating has 108000 miles on it . had the water pump and timing belt replaced for preventive maintance , at 88000 miles . any help out their ?
  14. djsamuel
    djsamuel Active Member Level 2 Supporter
    325
    I would check the condition of the radiator and also change the thermostat. If the thermostat is stuck closed, or even partially closed, you will overheat.
  15. mkaresh
    mkaresh Member
    3
    227 PT Cruiser owners now signed up. A good start, but more are needed to provide precise results for all model years.
    Not yet signed up? Details here:
