NewsWhat’s special about the Demon? • Demon has a freakin’ TransBrake • Pritchett’s Challenger Drag Pak isn’t a Demon
Rough idle at 1000 rpm
Discussion in 'PT Cruiser' started by Brenda, Nov 2, 2016.
  1. Alan Knodle
    Alan Knodle New Member
    1
    Another thing that can cause cold engine stumble and roughness is carbon build up on the back side of the intake valves.
    Brenda likes this.
  2. Gerry G
    Gerry G Member
    88
    It sounds to me the incorrect type of plug was used 2 years ago for the gap to have eroded from .40 (40 thousandths) to .46 (46 thousandths) in 10,000 miles. Hopefully they used the proper copper Champion/NGK or a double-platinum Champion/NGK or you may be replacing them again in 2 years. If they used the copper plug it should be replaced in 30,000 miles. The double-platinum should be replaced in 60,000 miles. Plan on a spark plug wire change next time the plugs are replaced.
    Brenda likes this.
