NewsFiery finish for Beckman – Updated with points • The official vehicle of Canada Day • Ram leaving “big rig” look behind?
Will not engage any gear
Discussion in 'PT Cruiser' started by rwaterson67, Feb 4, 2017.
  1. rwaterson67
    rwaterson67 New Member
    We took off the pan and changed the filter. Still no go. I did notice that the new filter seemed to have filter type material inside whereas the old one did not. Could that filter material have broken down and caused a clog somewhere?
    I will look into the linkage. Would it make sense that it would pop while driving? We were in drive going up a hill when it "disengaged".
    I am trying to believe that the trans has not just checked out as it was exhibiting no problems up until it just stopped engaging entirely.
  2. djsamuel
    djsamuel Active Member Level 2 Supporter
    325
    Hard to say. It is an easy check though, as described by Russ above. It would be worth the check just to eliminate the possibility.
  3. rwaterson67
    Well, I took out the airbox and battery. When we move the shifter through the gears it appears to be properly moving at the transmission side. I guess the metal on the magnet in the pan was evidence of a more serious internal injury... although some is to be expected with 176K miles on the car.
    I am almost resigned to the reality that this transmission is done.
