cars
Code PO 456
8 replies to this topic
#1 Jagawar
Jagawar
  • Inactive
  • 6 posts
Posted May 19, 2008 at 05:20 pm
2001 Dodge Caravan 3.3 engine mileage 101k The CK engine light is drivin me Mad.. I have sent it to the Dealer who suposed to have smoke tested it and found nothing. It is intermittent , it will sometimes stay out a week and then sometimes a day .. Code PO456 small emissions leak.. Has Anyone experienced the same prob? Please Help . :(
#2 chryslertech766
chryslertech766
  • Inactive
  • 482 posts
Posted May 19, 2008 at 06:47 pm
if its not leaking, then it probably needs a leak detection pump or a purge selinod.
#3 t2erns
t2erns
  • 1,416 posts
Posted May 19, 2008 at 08:32 pm
are you sure the dealer smoked it and found nothing? there are also independent shops that are capable of smoke testing the evaporative system. there's also a tsb regarding the erroneous setting of this code TSB 18-028-03 that involves replacing the pcm (if there's no leak indeed)
excerp from the tsb:
SUBJECT:
MIL Illumination, Erroneous DTC P0456 - Evap Leak Monitor 0.020 Leak Detected
OVERVIEW:
This bulletin involves diagnosing an erroneous Evap Leak Monitor (DTC) P0456 and replacing
the Powertrain Control Module (PCM) if necessary.
MODELS:
2001 - **2003** (RS) Town & Country/Caravan/Voyager (Domestic Markets)
NOTE: This bulletin applies to 2001 and 2002 vehicles equipped with a 2.4L, 3.3L and
3.8L engine (sales code EDZ, EGA, EGH or EGM), **and 2003 vehicles equipped
with 3.3L and 3.8L engine (sales codes EGA, EGH or EGM).**
SYMPTOM/CONDITION:
Vehicle with properly functioning evaporative emissions system repeatedly sets DTC P0456
when customer regularly commutes on a steep grade (downgrades in excess of 10%).
#4 dlstarry
dlstarry
  • Inactive
  • 17 posts
Posted May 19, 2008 at 10:43 pm
MODELS:
I have a 2003 Grand Caravan with 3.3L engine, could you tell me where to find the
sales codes you talk about in this message ?
Thank You
#5 t2erns
t2erns
  • 1,416 posts
Posted May 20, 2008 at 06:25 pm
MODELS:
Thank You
those sales codes are for engine codes (you can also find it in the vin plate)
Engine Code
EDZ = 2.4L 4 cyl. 16-Valve DOHC Gasoline (MPI)
EGA = 3.3L 6 cyl. Gasoline (SMPI)
EGH = 3.8L 6 cyl. Gasoline (SMPI)
EGM = 3.3L 6 cyl. Ethanol Flexible Fuel
#6 dlstarry
dlstarry
  • Inactive
  • 17 posts
Posted May 20, 2008 at 09:17 pm
Thank You
#7 Bobmob
Bobmob
  • Inactive
  • 11 posts
Posted November 8, 2008 at 03:52 am
MOST LIKELY ANSWER TO THIS PROBLEM
2002 T&C limited 3.8 65kI got this tip from a previous post and mine was exactly as the previous post described. Kept getting ck eng light with p456 code(Small EVAP leak). Tried new fuel cap, no help. Located EVAP canister under vehicle. There are 2 rubber hoses connected to the rear side. One of the hoses, I think the passenger side, was cracked where it connected to the cannister. It appears the hose is a little too small for the cannister port and it cracked over time. I just cut off the cracked portion with a razor blade and reconnected it. Havent had a ck eng light since.Update: Light came on again, P455. The hose cracked again so I replaced the entire hose with a much thicker walled one. This is clearly a design flaw, the original hose is too thin and the inside diameter is too small. It's sure to fail within 3 years....
#8 jimmy-ny
jimmy-ny
  • Inactive
  • 13 posts
Posted November 8, 2008 at 09:56 am
I don't know if this helps, but I had a very very deteriorated hose right near the purge solenoid on my Pacifica. I have older cars with hoses much older than the hose at the purge solenoid, yet this thing was cracked and split all over the place. Dry rotted.
There is a test port T right at the purge solenoid on the Pacifica. 5/16" I replaced it with a small piece of old fashioed rubber 5/16 fuel hose, slightly tightened the cap on the test port T and cleared the codes. Trouble gone.
But I also checked under the car (to be 100% sure) and inspected the canister hoses. Suprisingly, being more exposed to the elements than the hose above, these hoses were fine. I also inspected the hose from the filler tube to the gas tank. That looked fine as well.
Bottom line for me was the incredibly deteriorated hose at the purge solenoid. And I am just wondering as this is where the smoke enters the system for the smoke test (I believe) perhaps he overlooked an inspection at that point/area?
Jim
Edited by jimmy-ny, November 8, 2008 at 09:59 am.
#9 ImperialCrown
ImperialCrown
  • Supporters
  • Others:Forum Leader
  • 11,785 posts
Posted November 8, 2008 at 10:01 am
These can be intermittant and frustrating. Was there a leak but they just couldn't find where the smoke was coming from or was the system air-tight when they tested it? There was another TSB (#25-001-02A) for an intermittant LDP vent valve leak and like BOBMOB sez: Make sure there are no cracked hoses, after a few years they will dry-rot and split at the ends. The plastic lines are usually good unless they rub-through on something. Also we're seeing filler tube rust-through on these. It is behind the LR inner fender splash sheild and the smoke won't be visible to the tech.
Tool and Car Reviews · News
