cars
2002 Intrepid Cam Sensor Code P0340
9 replies to this topic
#1 ygdude
ygdude
  • 386 posts
Posted February 2, 2009 at 09:39 am
Hello.
The last couple of days I've had a bit of a stumble/hesitation while driving my 2002 Intrepid 3.5L w/106000 miles. Almost acted like it wasn't getting gas but had plenty. Stopped and got gas and breakfast this morning and had to do quite a bit of cranking to get it started. Also a lot of hesitation especially when giving a moderate amount of gas pedal. Also got the check engine light and the cruise control wouldn't come on this morning.
I looks like code P0340 is for the camshaft position sensor circuit? What does this mean? WHat/where should I check to fix this?
What happens if this completely fails?
Thanks for the help!
#2 ImperialCrown
ImperialCrown
  • Supporters
  • Others:Forum Leader
  • 11,767 posts
Posted February 2, 2009 at 09:47 am
The cam sensor is next to the left(driver's side) cam sprocket with a 3-wire connector and a single fastener holding it. Was that the only code? Check that the wiring hasn't rubbed through anywhere.
#3 ygdude
ygdude
  • 386 posts
Posted February 2, 2009 at 10:00 am
That was the only code this morning. In the past I've had, off and on again, a code for one of the O2 sensors reading wrong (rich I think).
#4 ImperialCrown
ImperialCrown
  • Supporters
  • 11,767 posts
Posted February 2, 2009 at 10:55 am
There is a TSB # 18-031-02 for false O2 codes on vehicles built before 4-18-02. It is a PCM flash.
#5 tlewis
tlewis
  • 61 posts
Posted February 2, 2009 at 01:19 pm
You might want to get that fixed, my '04 300M died within a few miles of that error code being set. The good news is that if you want to do it yourself, it is not that bad, if you don't mind unbolting the intake manifold enough to get clearance to change the sensor out.
#6 ygdude
ygdude
  • 386 posts
Posted February 2, 2009 at 01:45 pm
Thanks.
Where did you find the sensor? NAPA? How much were they??
#7 135SoHc
135SoHc
  • 2,790 posts
Posted February 2, 2009 at 02:02 pm
Advance auto, napa, dealer ect
Ours is on its 3rd one. The original went bad, then the new mopar one and now I've got one from advance auto BWD brand in there. dealer one was $55
advance $40 or so
About an hour to change it if you've never done one before
#8 ygdude
ygdude
  • 386 posts
Posted February 4, 2009 at 07:55 am
Thanks. I looked at the Haynes manual last night. It says to remove the upper air plenum and I see you at least need to pick it up out of the way to get the sensor out. Do you have to take everything off of the upper air plenum to move it enough to change the CAM sensor or do you just remove completely? I presume you have to lift it up high enough to at least change the gasket after its broken loose.
thanks.
#9 135SoHc
135SoHc
  • 2,790 posts
Posted February 4, 2009 at 09:11 am
You just need to lift it high enough to get that sensor out. There should be enough slack in all the wires that you dont need to unplug everything.
The gasket is reusable, just make sure the intake is sitting correctly and bolt it back down.
#10 droogy
droogy
  • Inactive
  • 2 posts
Posted July 8, 2009 at 08:49 pm
I'm experiencing similar symptoms, I've had the Camshaft sensor changed twice during the life of my 2003 Intrepid (currently 120,000 kms). P0340 and P0344.
I read somewhere on the net that this may also be a timing belt issue, is this a real possibility? Should I simply change the sensor first and see if it continues to pop up?
I think it's important to note that it's not a constant code. It will trip, after 3 starts light goes away, then a few weeks later it comes back. The intermittent nature of the codes means wiring issue or does this mean timing belt issue?
Tool and Car Reviews · News
