cars
The latest Mopar news: No summer vacation for many Chrysler plants • Fiat Industrial/CNH to be a UK citizen
The week’s features: Top 5 Missing Mopars  •  Sgt Bob Phillips, Police Car Pioneer  •  Imperial production and history  •  Ramchargers: Funny cars, Clorox, and riots
Welcome to Allpar, the Chrysler Car Community
Welcome to the Allpar forums for Dodge, Chrysler, Jeep, Plymouth, and other Mopar owners!  You must register to post, but this is a simple, free process.
Register now or sign in!
  • Use the collective Mopar knowledge of the community
  • Post, reply, and subscribe to topics
  • Make new friends
  • Join us at our annual meets
Guest Message by DevFuse
Low Oil Pressure On A 2.7
2 replies to this topic
#1 Brian D
Brian D
    Part of the Community
  • PipPip
  • 99 posts
Posted April 8, 2009 at 04:27 pm
I’m very frustrated. I have a 2001 Intrepid 2.7 with 133k that we purchased new. At around 100-105k(the majority highway miles and having used Castrol Syntec 10W-30 since 40k), the trans went bad so I pulled the motor and trans together. While I had the engine out I thought, given all the bad things I had heard about the 2.7, it would be a good idea to check and replace some of the internals. So I replaced the rods and mains even though they looked good, timing chain and tensioners, and water pump. Even though I found zero sludge anywhere, I also flushed out the oil pump and pickup, checked the oil return passages, and the passages to the oil filter and just to be safe, I pulled an old racer trick and slid a .050” shim under the oil pressure spring in the oil pump. Satisfied, I put it back together and drove off expecting to get another 100k.
At about 130k, my wife told me the oil light would flicker or come on at idle when the engine was warm, usually when she was stopped and in gear.
I checked my sources and read about the replacement wiring harness for the oil pressure sender, then I read about a replacement for the oil pressure sender.
I replaced the sender with a Genuine Mopar Part from a dealer, but no change.
This last week, I installed an oil pressure gauge and it read 45 lbs at cold idle going as high as 75 lbs at 3000 rpm. But when it warmed up, at 2500 in OD, the gauge needle rested on the pin and the only way to make it rise was to shift back into 3rd. At 3000 rpm, I can get about 5-7 lbs.
I know I have (or had) the correct clearance on the new bearings, I checked them all with plastigage and none of the journals had any scoring (had it been any other engine, I never would’ve replaced any bearings that looked as good as the originals in this engine).
My question now is; Should I have replaced the oil pump? Do these go bad on the 2.7? The engine is still quiet, idles without any noise, no clicks or knocks at all, and runs good. I was certain I had a faulty oil pressure sender and that is why I put a gauge in.
I’m really frustrated with this. Any and all help is greatly appreciated.
#2 ImperialCrown
ImperialCrown
    Lives Here
  • Supporters
  • PipPipPipPipPipPip
  • 9,858 posts
Posted April 9, 2009 at 02:47 am
I have never had a 2.7 oil pump fail. Not to say it couldn't happen but generally the oil pump is the best lubricated part in the engine.
I would much more suspect a widening of tolerences or relief valve/spring failure or even the oil pickup tube-to-pump o-ring failing.
I'd drain the oil and drop the pan for a look-see. Hopefully minor.
#3 Brian D
Brian D
  • PipPip
  • 99 posts
Posted April 9, 2009 at 08:19 am
Thanks for the reply ImperialCrown. I'm hoping :( for someone to give me a magic elixer fix.
I replaced the pickup tube O ring when I had the engine apart. I suppose I should have replaced the spring instead of shimming it, or maybe the whole pump. I have had others tell me that these oil pumps never fail, that it is always a bearing issue. I just didn't want to pull the engine again, and if that is what it comes to, I think I'll look for a 3.2 or 3.5. I have a wrecked 93' Eagle with a 3.5 that I was going to swap for the 3.3 into a 93' Concord I used to have but never got to it. I was told that the 93' 3.5 would not be worth the effort to try to swap into an 01'.
[Topic Google Ads]
Car Reviews · News ·
Please read the terms of use and privacy policy. We are not affiliated with Chrysler Group, makers of cars, minivans, trucks, and Mopar (TM) parts. We make no guarantees regarding validity or applicability of information, opinions, or advice. Posts may be edited and used in other parts of allpar.com and affiliated Mopar (Dodge, Chrysler, etc) car related sites. We have the right to remove or modify any message, and to ban or suspend any user without notice. Logos and site-specific information copyright © 2001-2010 Allpar LLC; Chrysler PR materials remain property of Chrysler Group.
