cars
Axle Tag Decoding
6 replies to this topic
#1 135SoHc
135SoHc
  • 2,790 posts
Posted June 15, 2009 at 02:26 pm
Found two tags on the diff cover. I was only expecting one tag for the ratio but found a 2nd one hidden under all the rust and grease.
one says 0759 and the other 3.2
assume the 3.2 is the ratio code for 3.21 since that seems to be a common ratio in these axles. but I have no idea what the other is supposed to mean ?
#2 ImperialCrown
ImperialCrown
  • Supporters
  • Others:Forum Leader
  • 11,780 posts
Posted June 15, 2009 at 05:07 pm
It could be the Julian date: 75th day of 1979.
#3 135SoHc
135SoHc
  • 2,790 posts
Posted June 15, 2009 at 09:14 pm
That would directly correspond to the build date of mid march
#4 bguy
bguy
  • 1,313 posts
Posted June 27, 2009 at 10:58 am
I'd almost bet money your axle ratio is a 2.94. IIRC my old 87 B250 had a 3.2 tag and I was quite suprised when the ratio inside was actually 2.94. The gears are actually stamped with the ratio. I wondered then if the 3.2 referred to the overall final drive ratio between tranny and axle.
#5 135SoHc
135SoHc
  • 2,790 posts
Posted June 27, 2009 at 11:58 am
I found the equipment tag in the glovebox a few days ago. one of the things it included was "RR axle 3.21"
#6 bguy
bguy
  • 1,313 posts
Posted June 27, 2009 at 02:03 pm
Yup. Mine was same. My label was under the hood I believe. The axle may have been changed, but it still had that 3.2 tag on it!! Go figure. <_<
#7 Trailmaster
Trailmaster
    Move Over Plymouth Aproaching Rapidly
  • 2,061 posts
Posted June 30, 2009 at 01:58 am
Used to see that sometimes in the wrecking yard. I think sometimes when people change the rear axle or ratios out, they just stick the old tag back on.
Tool and Car Reviews · News
