Welcome to Allpar, the Chrysler Car Community
Welcome to the Allpar forums for Dodge, Chrysler, Jeep, Plymouth, and other Mopar owners! You must register to post, but this is a simple, free process. Register now or sign in!
Hall Effect Sensor/pick-Up Coil
#1
Posted August 24, 2009 at 08:56 pm
From everything I have read on here and elsewhere on 1986 Chrysler Lebarons with a 2.5 TBI-non-turbo, the Hall Effect Sensor should be "in" my distributor?????
Dis. Cap off, rotor button out, and the distibutor is "hollow" like the inside of a coke can!!! I wiped down the inside of the distributor, and cleaned off a little carbon on the "new" rotor I put on in May.
Now, granted I am blind as a bat, but exactly where is this Sensor and how small is it? Is it up UNDER the distributor??
I even went and bought a Chilton book for 1981 to 1994 Chryslers front wheel drive 4 cylinders.
It shows exactly where it is for 1981 to 1985 FWD 4 cyl, 2.2 and 2.5L but nothing on a 1986 Lebaron. (My Luck!)
Can anyone help a dumb ole Tennessean. Seems all the info I read contradicts each other. The Chiltons book fault codes for my year of vehicle doesn't match anything on Allpar or Knize or Chrysler K-Car Forum.
I now know why when I take it in to the dealer or a mechanic they can't fix the problem because the info that is out there conflicts.
Any help would be appreciated as always.
Thank you.
#2
Posted August 24, 2009 at 09:07 pm
The HEP (Hall Effect Pickup) is under the distributor cap. For the TBI there is one connector at the end of a wire coming from below the cap which connects to the harness. This looks like a black disk. Without the HEP the 'walls' which spin as the distributor turns won't create the signal to fire the ignition and injector.
To detect a totally failed HEP disconnect the battery then once reconnected try to crank the engine. If it doesn't start pull the codes. If code 11 shows up it means that the computer did not receive any signal from the HEP indicating that the HEP is dead.
However, if it does start then the HEP may still be bad as in intermittent. But there is a possibility that it is a connection where the HEP connects to the harness.
#3
Posted August 25, 2009 at 07:46 am
Edited by Bob Lincoln, August 25, 2009 at 07:46 am.
#4
Posted August 25, 2009 at 10:12 am
If it still isn't there, can you post some pics? I don't recall a 2.5L ('86 and newer) ever not having a HEP.
I think I still have a Haynes manual at home for the '86 LeBaron GTS/Lancer. I'll try to remember and see if I can look this up.
#5
Posted August 25, 2009 at 10:26 am
Note that carbed HEP is smaller diameter than TBI. That what I found out.
Cheers, Wizard
#6
Posted August 25, 2009 at 06:07 pm
I even got "pictures"!! haha,,,,,,which by the way are being printed off along with all the instructions as soon as I type this!!!
I wondered what that wire coming out around the distributor was for.....now I know!!
Thanks again everyone!!
I'll let ya know know how it goes!!!
Home · Cars · Engines · Repairs · People Car Reviews · News · |
