cars
Which OMB2 Code Readers can read transmission trouble codes?
5 replies to this topic
#1 Miner
Miner
  • 26 posts
Posted October 2, 2009 at 11:49 pm
I would like to purchase an OBD 2 code reader. Can anyone tell me which one would would be capable of retrieving transmission trouble codes on a 41TE transmission. The Actron CP9175 AutoScanner is one of the one that I am thinking of buying. Also can a transmission code be retreived when the check engine light is not on? My vehicle is a 2002 Town & Country. Thanks.
#2 valiant67
valiant67
    Rich, Corinthian Leather
  • Others:Forum Leader
  • 22,482 posts
Posted October 3, 2009 at 05:36 am
That scanner will probably read any OBDII transmission codes. But it probably won't give you near as much information as a more expensive scanner. I use an old SnapOn MT2500 and it was several hundred dollars a few years ago. It allows me to read the TCM codes and the CVIs.
I am sure the transmission codes work like the rest of the codes. Some trigger the check engine light immediately, other are set as pending until they occur a certain number of times in a certain period.
#3 Miner
Miner
  • 26 posts
Posted October 3, 2009 at 03:50 pm
Thanks Valant67 for the information. It would be nice to be able to get the CVIs, but probably not necessary in most cases.
#4 alvin
alvin
  • 976 posts
Posted October 3, 2009 at 08:41 pm
Which MT2500 cartridges and cables are needed to read the transmission, ABS and airbag information?
Edited by alvin, October 3, 2009 at 08:42 pm.
#5 valiant67
valiant67
  • 22,482 posts
Posted October 4, 2009 at 06:47 am
If the vehicle is an OBDII one, you must have the OBDII cable adapter with the Chrysler personality key (most use key #13). I have two cartridges installed, domestic primary and domestic troubleshooter. They must cover the year range you want to diagnose.
If you have an OBDI vehicle, you also need the Chrysler 1 adapter and the Chrysler 2 adapter. I may have these backwards, but the Chrysler 1 adapter hooks to the underhood port for engine codes and diagnostics. The Chrysler 2 adapter hooks to the underdash port for the transmission, ABS (I think it has to be newer than the 91-92 or so Bendix 10) and other systems. Same cartridges as above.
#6 alvin
alvin
  • 976 posts
Posted October 4, 2009 at 11:46 am
Thanks a lot. It wasn't easy to find an answer to that question. So, in the case of OBDII, the only Chrysler-specific accessory would be the personality key. This is good to know.
Tool and Car Reviews · News
