cars
2002 Concorde Limited solenoid pack
5 replies to this topic
#1 rabbar
rabbar
  • Inactive
  • 3 posts
Posted October 4, 2009 at 10:12 am
Hello All...
I have taken my car in for the infamous "limp mode" problem with the transmission and have been told by
the Chrysler repair tech that I have a bad solenoid pack. It is recommended to replace the pack and have
the transmission flushed and have new fluid added. I have no problem with this except I cannot find the
solenoid pack part number ANYWHERE. I have found websites discussing different transmissions and
different parts, but I need the specific part number for my specific car. Any help would be greatly
appreciated. the dealer wants $588.00 to just replace the solenoid pack, not including the transmission
flush and fluid replacement. I would like to see if I can do better by finding the part on my own.
Thanks in advance for any help given.
rabbar123
#2 ImperialCrown
ImperialCrown
  • Supporters
  • Others:Forum Leader
  • 11,785 posts
Posted October 4, 2009 at 11:32 am
What were your fault code(s)? The sol pack on the 42LE is inside on the valve body (not external, like the 41TE). The reason that I ask, is that they don't fail that often.
#3 rabbar
rabbar
  • Inactive
  • 3 posts
Posted October 4, 2009 at 10:03 pm
I was told the fault codes were p0700 and p1776. The technician said he tested the transmission and it was good. I am not sure
how tested it, but I was relieved to hear it was ok.
#4 ImperialCrown
ImperialCrown
  • Supporters
  • 11,785 posts
Posted October 5, 2009 at 03:12 am
There was a TSB # 21-008-04A that gave diagnostic tips for this code (P1776)- Solenoid switch valve latched in the LR position. You want to be careful here, the solenoid valve is NOT located in the solenoid pack, but is in the valve body. There is a build date stamped on the valve body, if the Julian date falls between 3001 (300th day of 2001)and 0603 (60th day of 2003), replace the sol pack, NOT the valve body. You also want to rule out any shift cable mis-adjustment/wear issues. Make sure that your technician is aware of and reads this bulletin before spending your money.
#5 rabbar
rabbar
  • Inactive
  • 3 posts
Posted October 5, 2009 at 02:08 pm
Thank you for the information. Obviously there is a lot I do not know regarding this issue. It does seem to be a fairly
common problem though with Chrysler and I am surprised they don't have this problem down to a science by now.
I really do like my car and hope I can keep it running for years to come. I will have the date code checked on the
valve body as you have recommended and take it from there.
Imperial...thank you for your help.
rabbar
#6 plypete
plypete
  • Inactive
  • 233 posts
Posted October 6, 2009 at 09:46 am
I had the EXACT same thing on my wife's 2002 Intrepid. It was the faulty solenoid pack as the TSB describes. I had a trans shop do it and parts plus labor was only about $300-350. http://shop.oreillya...ype=424&PTSet=A
Tool and Car Reviews · News
