cars
1997 dodge intrepid dtc p0700 and p1782
5 replies to this topic
#1 jaydeee33
jaydeee33
  • Inactive
  • 3 posts
Posted March 18, 2010 at 05:00 pm
hello.
as stated in the title i have a 1997 intrepid 3.5 and i am pulling codes p0700 and p1782.
i was planning on replacing the transmission control module, as it doesnt look very difficult to do.
is this a likely cause for those codes? any feedback would be greatly appreciated.
#2 Stratuscaster
Stratuscaster
    Vaguely badass...
  • Supermen
  • Others:Supporters
  • 19,625 posts
Posted March 18, 2010 at 05:11 pm
I think one of our PT owners is having the same codes.
From what I've read, P0700 can be anything from the TCM to the input or output sensors to the TCM relay to something else.
I'd start with swapping out the TCM relay first.
#3 jaydeee33
jaydeee33
  • Inactive
  • 3 posts
Posted March 18, 2010 at 05:14 pm
okay. i looked in the fuse box under the hood earlier and did not see a tcm relay.
is dodge hiding it somewhere else?
#4 valiant67
valiant67
    Rich, Corinthian Leather
  • Others:Forum Leader
  • 22,447 posts
Posted March 19, 2010 at 04:14 am
All P0700 means is that the transmission computer has detected a fault, it does not mean a problem with the computer. You should ignore it and concentrate on the other code.
P1782 Chrysler 2-4 Pressure Switch Check which is another transmission code that may point to the solenoid pack. Unfortunately if it is the solenoid pack, it is internal on your car I believe.
Edited by valiant67, March 19, 2010 at 04:15 am.
#5 ImperialCrown
ImperialCrown
  • Supporters
  • 11,755 posts
Posted March 19, 2010 at 05:50 am
Does the trans go into 'limp-in'?
There is a TSB #21-02-98 that describes a new software release for the TCM. Among the enhancements is desensitization to intermttant pressure switch, speed sensor and gear ratio faults. It will still set the fault code, but won't put the trans in limp-in until the fault occurs several times.
The bulletin asks that the PCM also be at it's latest revision.
Has the ATF+4 and filter been changed recently? Cooler hoses dry?
TCM's and solenoid packs have a low failure rate. If there is an electrical problem, I would more suspect wiring first.
Edited by ImperialCrown, March 19, 2010 at 05:54 am.
#6 jaydeee33
jaydeee33
  • Inactive
  • 3 posts
Posted March 19, 2010 at 09:44 am
the trans is not in limp in mode. .
i have not changed the atf and filter since i got the car in july. .and it does have a coolant leak from one of the hoses where it meets the radiator.
do you suppose a bad ground could cause this?
Tool and Car Reviews · News
