cars
3.3 - 3.8 CARAVAN ENGINE SWAP
5 replies to this topic
#1 DUKTAPEKID
DUKTAPEKID
  • Inactive
  • 2 posts
Posted April 17, 2010 at 02:15 pm
I HAVE AN 01 GRAND CARAVAN 3.8 WITH A BAD ENGINE AND SOME MILES ON IT. I WANT TO BUY A LOWER MILEAGE WRECK AND SWAP IN THE ENTIRE RUNNING GEAR. THERE ARE VERY FEW 3.8'S AVAILABLE, BUT LOTS OF 3.3'S. CAN I SWAP THE WHOLE THING IN WITHOUT TOO MUCH PROBLEM? I'M WILLING TO STRIP THEM DOWN IF NECCESARY. ALSO, WHAT YEARS ARE EASY TO SWAP IN? ANY HELP WOULD BE APPRECIATED. THANKS, BILLY
#2 valiant67
valiant67
    Rich, Corinthian Leather
  • Others:Forum Leader
  • 22,470 posts
Posted April 17, 2010 at 05:58 pm
The interchange range is 2001-2003. You may be able to expand that by swapping components, but beware because the crank sensor may have changed type or orientation outside that range and that will keep you from getting it to run. But you will also need a 3.3 engine computer which must come from a 2001 3.3 minivan.
I'd try www.car-part.com and search for a 3.8 engine first.
#3 KOG
KOG
    KOG
  • 5,840 posts
Posted April 17, 2010 at 09:07 pm
And be aware that the transmission carries different transfer gears as the 3.8 is geared a little taller than the 3.3. That means you either change the transfer gears, which can be done with the transmission in the car, but isn't easy, or you swap transmissions as well.
You didn't tell us how many miles are on your van. You may be close to needing a transmission anyway. As well as struts, shocks, brakes, fuel pump and other expenses. Add that expense to swapping an engine and it may make more sense to scrap it and buy another one.
#4 richd
richd
  • 396 posts
Posted April 17, 2010 at 09:19 pm
With the transmission,I think you can put in the TCM from the 3.3 and it will work.
#5 KOG
KOG
    KOG
  • 5,840 posts
Posted April 18, 2010 at 01:56 am
It'll work, but it'll be overgeared so performance will suffer. And how long it'll work if the car already has 150K is also a real question.
#6 DUKTAPEKID
DUKTAPEKID
  • Inactive
  • 2 posts
Posted April 19, 2010 at 02:08 pm
Great, thanks for all the good info. That's what I planned on doing anyway, transferring the engine AND trans into the van, but I didn't know if I could use the 3.3 in place of the 3.8. I am goig to buy a wreck from Copart or one of those salvage auctions, but there are a LOT more 3.3's than 3.8's. I will have the whole van to pick off of, so I'll have everything I need. Thanks again, and I'll write in some more after I've got it done. I'll just make sure to get an 01 to 03 van with the running gear I want to use, so everything will work on the 01 T & C van that I have now. .
Tool and Car Reviews · News
