cars
Timing on a 1986 318 (5.2L) with a Mopar ignition
3 replies to this topic
#1 Kevman892
Kevman892
  • Inactive
  • 30 posts
Posted July 22, 2010 at 05:25 am
Hey guys, I know I've been posting alot of questions, but I'm not used to chryslers.. Anyway, it says in the car, that I should have my timing set at 12* BTDC, is this with the vacuum advance unplugged, or no?
#2 valiant67
valiant67
    Rich, Corinthian Leather
  • Others:Forum Leader
  • 22,482 posts
Posted July 22, 2010 at 05:59 am
You must disconnect and plug the vacuum line to set timing. You should also make sure the idle speed is set properly first as well. Some things to watch for:
1) The stock 12º timing may not work well with the conversion kit. It may want 10º or less.
2) Vacuum advance may be adjustable. The old kits you could adjust it using an allen wrench in the vacuum opening.
3) The springs in the distributor may provide more advance than a stock engine needs. The springs can be swapped if this is a problem.
It takes some fine tuning to get base, vacuum advance and mechanical advance timing where it needs to be with this kit sometimes. You want timing set properly so you get decent performance and good MPGs but with no pinging.
#3 Kevman892
Kevman892
  • Inactive
  • 30 posts
Posted July 22, 2010 at 05:17 pm
I changed it to 10*, starts 10X better, and runs like a champ!
#4 KOG
KOG
    KOG
  • 5,841 posts
Posted July 23, 2010 at 07:54 am
You're probably gong to have to set it at 5 degrees with a stock electronic ignition instead of the lean burn.
Tool and Car Reviews · News
