cars
are all 5 lug rims the same
3 replies to this topic
#1 toddsturbo
toddsturbo
  • 196 posts
Posted August 17, 2010 at 12:27 am
I know they come in different sizes of course but i pulled the wheels from the daytona so i have spares for my chevy cavalier.
They're both 5 lug rims and they fit on the cavalier.Only difference is the daytona's rims are 15 inch and the cavaliers are 14 inch.
The daytona is 195/60/15
The cavalier is 205/70/14
Iremember a while back a discussion about rim sizes and tires and how a taller tire will sometimes make up the difference with a smaller rim.
#2 Bob Lincoln
Bob Lincoln
    "CHECK FAULT CODES"
  • Supporters (L2)
  • Others:Forum Leader
  • 25,323 posts
Posted August 17, 2010 at 08:05 am
No, all rims are NOT the same for a given diameter wheel. The lug spacing can and does vary between and even within brands. My Daytona has a 5 x 100mm pattern.
http://www.mymopar.c...?showtopic=9623 See "bolt circle measure".
#3 valiant67
valiant67
    Rich, Corinthian Leather
  • 22,451 posts
Posted August 17, 2010 at 09:26 am
Besides the lug pattern, which is the same 5x100mm on the Daytona and the Cavalier, you need to also make sure the following are correct:
1) Offset - one wheel may have a different offset than the other meaning there can be rubbing on the inside or the outside.
2) Lug nut holes and taper - I believe these will be the same between the two vehicles mentioned, but they must match for the lug nut to properly clamp the wheel.
3) Center register - You want the center hole in the rim to match with the hub on the car. If the hole in the wheel is larger than the hub register, the wheel is relying on the lug only to hold the wheel in place. That is not ideal.
4) Width variation - the width of the factory wheel can vary by manufacturer, car line or even trim level on the same car.
If the rims fit, then what you need to do is use a tire size calculator to see what changing tire size will do, like this one:
http://www.1010tires...p?action=submit
It shows you will end up with about a 4% error changing the tire size.
#4 toddsturbo
toddsturbo
  • 196 posts
Posted August 17, 2010 at 05:36 pm
I'm not sure about the offset or width variation.The taper holes seemed to match up but i'm not positive on the center register.I don't have a visible hole on the daytona rims as that part is covered up.
I bought the tires new a few years ago and hate to let them go while they still have good tread on them.I'm selling the daytona tommorrow and put an old spare set on.The folks buying it are most likely gonna part it out so i wanted to try and salvage my good tires.
I'm getting $250 for it which is more than i'd get by calling the junker to come haul it away.If they want to buy the tires for a few dollars more then i may just do that.
Tool and Car Reviews · News
