cars
2006 Grand Caravan Headlight problems
1 reply to this topic
#1 Tallguy67
Tallguy67
  • Inactive
  • 4 posts
Posted December 28, 2010 at 11:38 am
Folks,
My kid sister called me last night, she is having a weird problem with the headlights on her 2006 Grand Caravan. Her daytime running lights are working fine but when it got dark and she turned on her headlights she noticed that she has no normal headlights and she only has high-beams when the control arm is held toward the driver. As soon as you let go of he arm, it should toggle high beams on/off but when the arm is let go, it goes back to only drl. I honestly don't know where to suggest she start - fuses, lights or the multi-function switch in the column. She has to drive back to Alberta through the mountains from BC in a few days. Any suggestions would be appreciated. I am new to allpar so if I have posted in the wrong area just let me know where I should have posted.
#2 ImperialCrown
ImperialCrown
  • Supporters
  • Others:Forum Leader
  • 11,779 posts
Posted December 28, 2010 at 02:13 pm
The DRL runs the high-beam filiments at ~50% and the high-beams (optical horn or flash to pass) are all that work on the headlamp stalk. Is it possible that both low-beam filiments are open? These can be tested for continuity with a meter and you may physically see a break in the filiment through the glass. Avoid touching the glass envelope as fingerprint grease can blow the lamp if it is otherwise OK.
Really everything 'headlight' is module-controlled. The multifunction switch sends a signal of what is being selected to the BCM (body control module) and the BCM sends a signal over the PCI bus to the FCM (front control module) which controls the headlamp operation. There may be fault codes stored in either module to assist in diagnosis and a good scan tool can show what the modules are or aren't seeing with the headlamp switch turned on. .
HEADLAMP SYSTEM
The configuration of the headlamp system of headlamps, park lamps and fog lamps is determined by the BCM. The BCM determines the lighting configuration as a result of the inputs from the ignition switch, headlamp switch and multi-function switch. A PCI bus is transmitted from the BCM to the FCM to enable the necessary drivers to set the illumination configuration. Four wires are connected between the headlamp switch and the BCM. The first wire contains information regarding the position of the headlamp switch (Off, Automatic Headlamps, Automatic Headlamp switch fog, Park with Fog, Head, or Head with Fog Lamps). The second wire contains information regarding the position of the dimmer switch (Dome Lamp, Daytime Brightness, Dimming Level or Off). The third wire is a dedicated signal return (ground) wire. The fourth wire provides power to the front fog lamp indicator.
Tool and Car Reviews · News
