Welcome to Chrysler, Dodge, Jeep, Plymouth, and related cars and trucks
Welcome to the Allpar forums for Dodge, Chrysler, Jeep, Plymouth, and other Mopar owners!  You must register to post, but this is a simple, free process.
Register now or sign in!
  • Use the collective Mopar knowledge of the community
  • Post, reply, and subscribe to topics
  • Make new friends
  • Join us at our annual meets
Guest Message by DevFuse
What number are my tail/parking lights? 1977 cordoba
10 replies to this topic
#1 roger_27
roger_27
    Part of the Community
  • PipPip
  • 97 posts
Posted December 23, 2011 at 11:00 am
Hey I want to go aorund and replace ALL of my bulbs with LEDs.
I am also going to replace my flasher with those solid state ones that are LED friendly.
Does anyone have (off of memory or on hand) a list of what numbers all the external lights are?
turn signals in front
brake/turn signals in rear
clearance lights on the sides of the body in the front and rear
opera lights?
Another question is that I see 2 or 3 different STYLE of LED bulbs. will they always fit into the housings??
like this
http://www.ebay.com/...=item336f6683e4
versus this
http://www.ebay.com/...=item2c61ae363a
versus this
http://www.ebay.com/...=item1e66ed4268
any help is appreciated. Thanks.
Edited by roger_27, December 23, 2011 at 11:03 am.
#2 valiant67
valiant67
    Rich, Corinthian Leather
  • 19,782 posts
Garage View Garage
Posted December 23, 2011 at 01:01 pm
Going from memory, the rear tails should be 1157 and the front turn signals 1157NA.  The side markers are probably 198 or something similar.  I've never had an opera lamp bulb quit working so I never replaced one.
I'll see if I can verify these numbers alter.
#3 68RT
68RT
    Prolific
  • PipPipPipPipPip
  • 4,092 posts
Posted December 23, 2011 at 01:34 pm
As far as the socket is concerened, all of them will fit. Concerns would be about how does each work with YOUR reflector and will the leds touch your reflector before the lamp is able to be pushed in far enough to twist into the locking position. Some reflectors have a very narrow access that could be a problem.
I show a standard 1157 for the stop/tail light and an Amber 1157 for the turn/parking light. The cornering light would be an 1156 and the markers a 168.
#4 roger_27
roger_27
  • PipPip
  • 97 posts
Posted December 23, 2011 at 01:47 pm
Thank you both for such timely responses!!!
I'd like to think that they just took the dimensions of the actual bulb, and made the LED's fit INSIDE the same contour-shape.
I'm afraid I will end up with ones that are so wide I can't slide them in from the back as intended, but rather they are made to be inserted from the front.
Or as you said they could be too long and hit the reflector
#5 68RT
68RT
    Prolific
  • PipPipPipPipPip
  • 4,092 posts
Posted December 26, 2011 at 10:23 pm
Image #3 seems to be able to fit within the confines except for overall length being longer. None of the three posted images  seem to use the reflector very well.
#6 charger383
charger383
    Active
  • PipPipPip
  • 296 posts
Posted December 29, 2011 at 08:39 pm
The ones in image #1 use the reflector much better than the one in image #2.  If one in image #3 will fit, then it may be better.
Keep in mind that the junky LED replacement bulbs are way too dim.  So the brighter the better, and it needs to emit light at all angles, not just forward.  Also, for the tail lamps, you want red LEDs.  And for the amber lamps, you want amber LEDs.  Do not get white ones in either case and put them behind a colored lens.  White LEDs aren't as bright behind colored lenses as the actual correct colored LEDs are.
From personal experience, I have red ones similar to image #1 in both my Charger and my '69 truck.  They work well and have a decent light spread from the reflector.  A friend of mine tried ones similar to image #2 and they were terrible -- just a small circle of light in the middle of the tail light lens.
Also be careful.  That first auction you posted has a Buy It Now price if $51!  You should be able to find a better price than that.  I also suggest sellers from the USA.
Here is a good guide to answer some questions:  http://www.v-leds.co...e/ledGuide.html
I've bought stuff from v-leds before when they had an eBay store.  But they closed the eBay store earlier this year for some reason.  And now their prices are high on their own eCommerce site.
Edited by charger383, December 29, 2011 at 08:51 pm.
#7 roger_27
roger_27
  • PipPip
  • 97 posts
Posted January 6, 2012 at 10:13 am
Thanks so much for the help.
but what's a cornering light?
I have 2 rear lights, 2 front signal, 4 clearance lights around the car (2 red, 2 amber).... so..... I can't think of another double filament bulb known as a "cornering light"
#8 68RT
68RT
    Prolific
  • PipPipPipPipPip
  • 4,092 posts
Posted January 6, 2012 at 11:48 am
Cornering lights were available on some models and they came on with the turn signal and were a single light that helped illuminate to the side that you were turning toward. Not that common but your year has a listing under Chrysler and it looks like they were standard on the Imperial.
#9 valiant67
valiant67
  • 19,782 posts
Garage View Garage
Posted January 6, 2012 at 08:38 pm
Cornering lamps weren't offered on the Cordoba until 1978.
#10 DaveAdmin
DaveAdmin
    Administrator
  • Supermen
  • PipPipPipPipPipPipPip
  • 13,858 posts
Posted January 7, 2012 at 08:23 pm
Strongly suggest http://www.danielsternlighting.com/
#11 roger_27
roger_27
  • PipPip
  • 97 posts
Posted February 3, 2012 at 01:27 pm
When I purchase them in a month or so I will report back with my findings. thanks for the help guys!
Car Reviews · News ·
Please read the terms of use and privacy policy. We are not affiliated with Chrysler Group, makers of cars, minivans, trucks, and Mopar (TM) parts. We make no guarantees regarding validity or applicability of information, opinions, or advice. Posts may be edited and used in other parts of allpar.com and affiliated Mopar (Dodge, Chrysler, etc) car related sites. We have the right to remove or modify any message, and to ban or suspend any user without notice. Logos and site-specific information copyright © 2001-2010 Allpar LLC; Chrysler PR materials remain property of Chrysler Group.
